[ROM 10-3-12]GingerDX JB UI on CM7+Sense2/3 lockscreen
ThatGuyLurkin
2,155
665
This Rom is originally by Doixanh, but was continued by XDA members. You can find the Original Thread here.
http://forum.xda-developers.com/showthread.php?p=16042657#post16042657
GingerDX
Now under new management( By EagleEyeTom )
Intro
Let's continue the fun! :)
This project is a continuation of doixanh's personal ROM, known as GingerDX.
("Ginger" as in "Gingerbread", and "DX" as in short for "doixanh")
Brought to you by Team GingerDX:
eagleeyetom and djnilse
As set in stone by doixanh, the main goal is to have a fast, smooth and lightweight CM7 based ROM with some special features.
Features
[*]Fully working Camera :D
[*]Minimal number of apps are installed.
[*]Lightweight
[*]The usual things as with other ROMs: WiFi, BlueTooth, USB, Sensors, 3D, Video, FM Radio, Camera, Rooted, JIT,
ZIP-aligned, App2SD, ...
[*]WEP AdHoc support
[*]CallMeLouder: Louder ringer when the phone is inside a bag or pocket.
[*]Improved Flipping down mutes ringer
[*]Flipping down snoozes alarm
[*]Back button ends call
[*]Built-in Transparent Status Bar support
[*]Hide avatar in SMS
[*]Quick Copy / Quick Paste
[*]View.measure() method caching for improved 2D performance
[*]Custom carrier text
[*]Built-in loop ringtone support without OGG editing
[*]Optimized ("smoothened") scrolling/flinging
[*]Random Lockscreen
[*]Sense Lockscreen / Boot sound / Ringtone / Live Wallpaper
[*]Sleep button on Power Control widget
[*]Center clock on status bar
[*]Status bar battery indicator
[*]Configuration section (with localization for many languages)
[*]EduRoam WiFi compatible!
[*]GalleryDX (replacement for Stock Gallery, based on QuickPic)
[*]ICSified by integrating AChep's ICS Layouts natively into the ROM (a/k/a "AChepified")
This is here to stay, we won't revert to the standard Gingerbread style
[*]AChep's ICSandwich Theme included and set as default
[*]ICS Wallpapers added into CMWallpapers
[*]ICSified Settings by djnilse
[*]GPS Country Optimizer by djnilse
[*]Pick-up-to-call by djnilse
Pick-Up-To-Call in phone dialer and MMS
? Enable it in Settings -> CyanogenMod settings -> GingerDX settings
? Type the number in the dialer
? Move it to your ear (or pull your finger on the proximity sensor and hold the phone vertically) and the number will be called
? Same in Mms, there it just calls the number of the chat/sms you're reading
[/list]
Known Bugs
Camera sometimes doesn't connect(Ill look into it)
DO NOT CHANGE LOCKSCREEN BACKGROUND WITH SENSE 3 LOCKSCREEN, It will bootloop
No root currently(Ill fix today)
Downloads
Rom - http://db.tt/3XvennP2
My Gapps(NOT NEEDED) - Test2.zip
You don't have to flash Gapps, but I always do.
Install Instructions
1. Wipe EVERYTHING( I recommend Leslieann's zips) http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/164127-easy-wipe-zips.html
2. Flash Gapps
3. Flash tweaks?(Beats?)
4. Boot, and enjoy
Themes
* Taine0's Revolution theme - Revolution Theme - CM7 theme (HDPI+M/LDPI) - xda-developers
* AChep's ICS theme - [Theme] Ice Cream Sandwich | 032-build-408 | 29.04.12 - xda-developers
Re: [ROM-PORT] GingerDX CM7+More Features!
Screenshots
NEW UI
Reactions: drm1992
Looks quite nice! I would try if I wasn't on ICS, but still, great job!
Curiosnoob ported before but never released this is tight
Sent From My Speed Demon Go Kart
Nice work. I love the long long list of features. Downloading now. Just one thing it's no big deal but in your instructions you forgot "flash the rom" lol. Technicalities ;)
Sent from my three wheeled unicycle equipped with NOS
Looks like cyan mobile has some competition! Great job bro!
This ROM is currently under review. Links (may) come back shortly.
So far so awesome. Loving everything so far. Great work and thanks a million TGL!
Just be aware of bootloops :P
I ran into 2 and had to reflash ;)
None for me yet but I haven't themed or changed the lockscreen at all. Or even oc'ed yet lol. This is running way smooth at 600
[mod edit -- removed quote of OP]
So jelly right now _-_
Sent from my One V using Tapatalk 2
khalid345
