Results 1 to 7 of 7
    inceyet's Avatar
    Posts
    ROM
    MIUIgb
    Default Need help
    OK here's the deal. Every time I flash
    Xperia ics the time is completely off by hours. Also I get a old wallpaper I don't even have anymore . So with the advice from clodfelterac I reformatted my SD card and it did the same thing btw I redownloaded the rom. Any thoughts .brew this isn't the first time thus has happened. Advice. Thanks
  2. #2
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,017 Global Posts
    ROM
    Stock
    Default Re: Need help
    If it's an ICS ROM the clock is a known problem.
    The wallpaper gets backed up with your Google account, so when you go through the set up and you check the Restore box, you get your old wallpaper back.
    Thanked by:
  3. #3
    What Cole said.
    Try doing the aame process, but signing into Google from the menu instead of the Set Up screen.
    Thanked by:
  4. #4
    clodfelterac's Avatar
    Samurai Dev
    Posts
    ROM
    IllusionB / OM
    ive done it both ways with no problems... though i do usually skip the google sign in until after the roms fully booted... and then sign in via settings>accounts and sync... then i adjust all the settings the way i want and reboot... then i activate playstore , update su, install root browser, delete the unneeded gapps, install all my apps via root browser from backups on sd, and then reboot... then i activate all the apps one by one and sign in/adjust app settings... finally, i reboot recovery, wipe cache/dalvik>reboot... after its fully booted, i reboot recovery and make a nandroid... but everyone does things differently... :-)
    Thanked by:
    inceyet's Avatar
    Posts
    ROM
    MIUIgb
    Good looking out y'all for the quick response I'll take a look at it tomorrow. I'll let y'all know the results, also the time issue any work around this is the first time I've had this issue. One more thing its norm after boot that it goes straight to the lock screen and not to the regular set as I get w/aokp. Again thanks yall
  6. #6
    I also noticed that you have to go into the theme chooser and apply the xperia theme for the wallpaper
    Thanked by:
    inceyet's Avatar
    Posts
    ROM
    MIUIgb
    This thread is dead
  1. New to Android phone and need help
    By ntapia82 in forum Samsung Moment
    Last Post: 04-26-2010, 05:40 PM
  2. Android Rookie with the HTC Hero I need help!!!!
    By bigrich34 in forum HTC Hero
    Last Post: 10-14-2009, 12:15 PM
  3. getting started, need help !
    By android for dummy in forum General Help and How To
    Last Post: 09-24-2009, 08:28 AM
  4. Need help regarding my google search bar on my g1
    By wabbit3119 in forum General Help and How To
    Last Post: 09-01-2009, 04:41 PM
  5. need help please
    By jfchica1987 in forum T-Mobile G1
    Last Post: 06-16-2009, 02:12 PM
