Results 1 to 6 of 6
    Default Flashing with ADB using batch/script?
    Is it possible to set everything up in a batch file or script so that flashing a ROM is as easy as plugging the phone in and running the script? Anyone done it yet?
    I noticed there's a Windows app that basically does this for HTC phones. ].
    Optimus V (VM670)
    Cold as Ice alpha 19 (CM9)
    Cannibal Open Touch 2.1
  2. #2
    Default Re: Flashing with ADB using batch/script?
    You can use commands, but you need to use the Amon based recovery. Its old, 100% working, and only works on old screen.
    You can use ADB on windows. You prepare the zip, plug it up, ADB push it to Data, flash, wipe data, then boot phone.
    It takes the same time as flashing it via the phone as well.
    I'm curious why that UniFlash doesn't mention specific recoveries, since it sound like it's doing what I want to do only with a nice GUI. It's reported to work with the Optimux One (P500), and Optimus 2X support is on the way. Perhaps it will will with the Optimus V?
    Optimus V (VM670)
  4. #4
    Wouldn't hurt to try as long as you flash a rom and not a radio.
  5. #5
    Repost?
    UniFlash for Optimus S
    If you're you're asking if this thread is a repost, then I don't think so. I merely mentioned UniFlash as an example of someone using ADB to flash a ROM. My original question was in regards to looking for a way to do it using ADB through the command line via a batch/script, for a more simple one-click.solution.
    Optimus V (VM670)
  1. Copy/Wipe/Flash with ADB
    By BlackHawkA4 in forum Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Last Post: 09-07-2011, 04:06 AM
  2. will the INC get flash with 2.2
    By tada1096 in forum Verizon Droid Incredible
    Last Post: 06-08-2010, 11:45 AM
  3. cant use the flash with video?
    By UTnick in forum HTC EVO 4G
    Last Post: 06-06-2010, 11:16 AM
  4. Replies: 0
    Last Post: 05-06-2010, 02:12 PM
  5. help with adb sdk to overclock droid
    By logodude in forum Motorola Droid
    Last Post: 02-03-2010, 12:42 PM
