Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree6Likes
    countmypennies's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to Get more internal storage space Help
    I have a Virgin Mobile LG Optimus V and getting tired of not being able to install apps or installing apps and removing others cause I have no internal phone space right now it shows 18.6megs but in no time I get the low on space message when loading apps..
    I've already moved all the apps I can to the SD card but just not enough. Could someone direct me or tell me a solution or can I purchase more memory ? anything? very frustrating not being able to use the phone for what apps I want..
    by the way my phone is already rooted with gingerbreak if that makes a difference
  2. #2
    gump45's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Froyo(?)/2.6.32.9
    Default Re: How to Get more internal storage space Help
    I had the same issue for the last couple of months. Once you have root permission you need to partition the microSD card using another app. Partitioning the microSD card, so that you have at least two (2) partitions, will give you room to store apps on the card, instead of trying to cram it all into the tiny (less than 200-MB) space available on the phone itself. Once you have done that use another application, like Link2SD, that allows you to install more of your applications to the microSD card by creating links between the phone and the card, and keeping the apps on the card. I think I got that right. Here's the opening text from the Link2SD application page: "Link2SD is an application that makes it easy for Android 1.6+ users with root privileges on their phone to move applications to the SD card."
    I am still researching these for myself, so I can't guide you there. I already have Link2SD installed (you can find it in the Google Play store, play.google.com. I still need to find a partition manager to use.
    Hope this helps point you in the right direction.
  3. #3
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What size and class sd do you have
    There are custom roms that utilize scipts to mount your sd to your internal memory as well as link2sd
    You will need to format your sd accordingly and partition with an ext3 or 4
    If you can set aside 1 gig for ext4, you can have that as internal storage
    However a higher class sd is recommended as it can talk better with your phone
  4. #4
    daffy_duck_nj's Avatar
    DUCK!
    Posts
    Global Posts
    197 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    LG Optimus F3 JB412 root
    After gump's suggestion, you'll need to learn how to install a ROM onto your phone. Look at LeslieAnn's sticky for more details, and read it carefully. Trust me, it works, but you'll need to set aside enough time to do this... perhaps at least two to three hours. Keep a PC open while you do it so you can ask some questions here. My personal suggestion for a good, stable ROM for the V is either MiRage 7.2 (my personal favorite) or Harmonia 2.
    adamhos likes this.
  5. #5
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would recommend Om mandy once you are partitioned
  6. #6
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    [CyanogenMod-7 ROM+KERNEL] OM-Mandylion.....01-12-2013..Update
    OM-Mandylion....[IHO ROM+KERNEL].....09-30-2012..Update
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there any step by step guides for this process I can refer to? I don't want to brick the phone doing this..
  8. #8
    carloswii5's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quattrimus,
    Quote Originally Posted by countmypennies View Post
    Imma post a tutorial tomorrow cause the ones I've seen are outdated and Imma make it noob-friendly also
    Sent from my Cyanonized Opt V
  9. #9
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you have a custom recovery?
    Youll want that first
    Cwm blue or xionia or teamwin or cot
    When you have that make a nandroid backup from recovery
    Then backup your sd to your pc
    Once your backups are complete,
    Format your sd
    Then you can partition (ext 4 1gig) with your recovery menu or through your pc with mini partition tool(google it)
    Once you have partitioned, copy your sd backup back to your sd
    Then from recovery wipe system, data, cache, and dalvik cache
    Install (flash) rom.zip of your choice
    Flash gapps
    Reboot
    Reboot again
    Then log in, sync, add your apps and settings
    Enjoy
  10. #10
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The rom i linked to above has a nice description of the process as well,
    If you need help ask or search the forum and check stickies!
  11. #11
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Attached Thumbnails Attached Thumbnails How to Get more internal storage space Help-uploadfromtaptalk1349566239689.jpg
  12. #12
    bjzapp's Avatar
    Where did u hear tht word
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MiRaGe - IHO CM7.2
    Quote Originally Posted by adamhos View Post
    Format your sd
    Flash gapps
    Reboot
    Reboot again
    Enjoy
    is this really true?...
    you have to wipe the system, data, and everything else and re-flash the ROM just to partition the card?
    I thought that the Recovery could take care of that and just had to format the SD then re-copy from a computer...
    Then use the Link2SD app to recgonize or find the partition.
    Obviously I have not done this as of yet, but would like to
    thx
  13. #13
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,029 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by bjzapp View Post
    thx
    You're correct. The user he was responding to gave no details about their current setup, first impressions is that they don't have a custom recovery or ROM.
  14. #14
    bjzapp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MiRaGe - IHO CM7.2
    Quote Originally Posted by cole2kb View Post
    YAY !!
    Well, I did at least one thing right so far today LOL
  15. #15
    webbos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same problem as the OP. I rooted and installed Harmonia 2. All was well, and I went from 12MB internal storage free to 120MB free
    But, now I hit another issue even with all that storage free. I now get an insufficient storage error when trying to download apps from the Play store. From doing some reading I've tracked it down to the fact that my /cache/download directory only has 10Mb free. Looking in Link2SD it's set to be 110MB and I'm using 100MB of it. Will following the above instructions of creating the second partition on the SD card help out at all ? If not, anyone have any ideas ? As I assume the OP might eventually have this issue too.
  16. #16
    Locool676's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Harmonia 2
    Quote Originally Posted by webbos View Post
    This issue is from not only a full download cache, but a full Dalvik Cache. If you look over to the Harmonia 2 thread, I've got some fixes going on to alleviate this problem.
    Here's my post. Feel free to do what I've mentioned, and try out the new A2SD++ script that I've looked into.
  17. #17
    webbos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the link and suggestions. I installed the A2SD++ script. Initially caused a load of FC's, which were fixed with a reboot. The data folder was moved successfully, and the /cache/download folder was reduced by 50 Mb (a good thing). But, there was a definite slow down in the phone's responsiveness (probably due to stuff being on the sd card now. Also all of my apps that I had previously moved to the sd card were now broken (said they weren't installed). So, I think that I'll try and find a solution to just move the whole cache folder to the sd card, and not mess with moving the data folder, which wasn't a major issue for me anyway.
  18. #18
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Personally, I don't use a2sd, I use the d2sd and have had very good luck with it
    Once in a while it will break certain roms but for the most part I never run out of space
    Sent from my VM670 using Android Central Forums
  19. #19
    Kim Kurz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How do you get the partition thing for the microSD card? Like what do you search? My phone says it'd low on space like as soon as i get on the internet or install an app and I don't even have anything on my phone. No apps no games.. what do i do to make this stop happening?
  20. #20
    EarthnFire78's Avatar
    YAY!!! ME :)
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Custom ROM & Kernel
    Quote Originally Posted by Kim Kurz View Post
    Are you rooted, if not what does the baseband version say under Settings > About phone?
  21. #21
    AndyOpie150's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Bean_Whiz-CM10v2.2.2CX
    To get the best results. Use the partition SD card option found in a custom recovery like the ZenGarden recovery. Developed by the previous poster.
    You can only use no more than 20% of the actual storage space on the SD card for a partition, but Link2SD works best with a 2GB partition. You need an SD card with enough actual storage space, that at the very least, will allow you to to have a 1GB partition.
    If you use an 8-32GB SD card it is almost imperative that you use the recovery to make the partition. You can then change the partitions format to whatever you need with Mini Tool Partition Wizard.
    I like to flash a fresh ROM then install Titanium Backup ,widget apps, Root Uninstaller, and Link2SD.
    Open up Link2SD and choose the format of the partition you made on the SD card. Then reboot.
    After your phone revolts, open up Link2SD and go to the menu and select the "Auto Link" function.
    Close and then open up Titanium Backup. Restore your apps.
  22. #22
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by AndyOpie150 View Post
    You sure like pushin that recovery lol....are you getting paid lol
    Jk...actually its a great recovery, i swear every post I read of yours you are pushin it
    Sent from my HTCEVOV4G using Android Central Forums
    EarthnFire78 likes this.
  23. #23
    YAY!!! ME :)
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Custom ROM & Kernel
    Some people push the COT recovery too, and that is a great recovery and would be better if the Windows drivers were updated.
    Speaking of getting paid, I'm most likely going to start taking donations in about a month for the Project SuperiorIrkenOrgans.
  24. #24
    adamhos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by EarthnFire78 View Post
    Lol, you do nice work
  25. #25
    Kimdvm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry if I'm being dense here, but how do you increase your internal storage? I was running MiRaGe with a 16GB sd card and using link2sd and internal storage was still almost full. I just flashed Harmonia and Internal storage is showing total space 179MB and available space 154MB. I don't want to restore any more apps if I'm just going to run into the same problem.
  1. Help! looking how to get free mins using google voice of VOIP
    By Aruen91 in forum Virgin Mobile Optimus V
    Last Post: 04-12-2014, 10:40 PM
  2. How to get more _internal_ memory
    By dmullens in forum AT&T LG Phoenix/Thrive
    Last Post: 07-06-2013, 09:36 PM
  3. How to get into recovery-Please help
    By nat72sherman in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 07-10-2011, 08:33 PM
  4. HELP: How to get to stock from CM7
    By ryman222 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 05-15-2011, 06:19 PM
  5. Need Quick Help- Forgot how to get into recovery menu
    By TVCMI in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 04-02-2011, 02:58 PM
