Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By upconvert
    flapjack.fiasco's Avatar
    Posts
    ROM
    Cold As Ice - Alpha 19e
    Default Making Room in /System...
    I've been interested in getting Google Now to work in ICS, but I haven't been that vigilant in trying until recently. Here's a thread on how to do it:
    So, according to this thread, the key to getting it to work is freeing up 30 MB on the /system partition. This is proving to be more than a little difficult. I'm running Bobz CM9.1 right now, and I can only get about 20 MB freed up. I've moved all ringtones, alarms, and notification sounds to the SD-card. I've removed some unnecessary system apps. I'm struggling to find anything else to remove.
    So here's my question: what else can be safely moved/removed from the /system partition? Or, alternatively, is there another ICS ROM that has more free space available in the /system partition?
    This space intentionally left blank.
  2. #2
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default Re: Making Room in /System...
    Get rid of most of the fonts. There's a small droidsansfallback.ttf in my alpha 17f you can use. Or compare font folders. It just drops Japanese and Chinese letters. I think I had around 25 mb without removing anything else. Another place is tts folder, keep English only. And try my ics gapps. Get rid of wallpapers and find the smallest latinime.apk.
  3. #3
    I got mine up to 34MBs, but Google Now didnt open for me. So i gave up on it.
    Thanked by:
    Posts
    ROM
    Quote Originally Posted by thekraven View Post
    Awesome, thanks for the tips! I think I removed the wallpapers already, but I'll double check. The other methods are gonna take a bit more time, so I'll report back after work. Thanks again!
    Quote Originally Posted by ThatGuyLurkin View Post
    Yeah, it's not something super important to me, just something that I'm curious to try. But thanks for the heads up, and if I get it to work, I'll let you know what I did.
    Thanked by:
    Posts
    ROM
    I finally freed up enough space in the system partition. I ended up using TheKraven's Cold As Ice ROM. I tried to put parts of it in BobZhome's CM9.1, but it wasn't working out for me. CAI just has more free space in /system to start with, so it was easier to trim it down. I highly recommend it to anyone who hasn't tried it out yet. It's impressive! Time to try installing Google Now! Finally...
    Thanked by:
  6. #6
    Badboytoast's Avatar
    Posts
    Global Posts
    822 Global Posts
    ROM
    ICS 2.3.7/ tvall kernel
    If you look In Bobz cm10 thread someone posted a more them 90% working Google now! Sorry can't remember his name but the quick searchbox .apk its only about 4.5mb and scrolling work!! Is. Using it now!!
    IF I Help You In Any Way Please Push The Thanks Button [HL]It Feels Good To Know You Helped!![/HL]
  7. #7
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    I can't do it until voice search works. Otherwise I'm gonna have to explain to my wife that google now is like siri, but better and faster, except voice search doesn't work yet.
    terthii likes this.
  8. Thread Author  Thread Author    #8
    Posts
    ROM
    Quote Originally Posted by Badboytoast View Post
    Awesome! But I imagine that method doesn't work for CM9. I'd love to be running CM10, but there's a few bugs holding me back. The RIL issue is annoying, and every time I try to install SwiftKey, I get a force close on system settings. I've checked the md5, reinstalled several times with different downloads. Oh well.
  9. #9
    TauSigmaNova's Avatar
    Domo Arigato, Mr Roboto!
    Posts
    ROM
    CM10|Stk/CM10.1|4.1 AOSP
    Hmm, I know the feel. Getting GNow to work on Vanillabean was a pain in the *** >.>
    Happy Nexus 4 User
  1. help- droid x rooted and cant install in system/app
    By 66racer in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 11-29-2010, 01:12 AM
  2. phone makes calls in speaker by default?
    By whitehorse84 in forum HTC EVO 4G
    Last Post: 11-04-2010, 10:36 AM
  3. 2.2: Can't Access All Apps In System Tray
    By mkalka in forum Motorola Droid
    Last Post: 08-11-2010, 04:18 PM
  4. Replies: 0
    Last Post: 06-02-2010, 10:12 PM
  5. Replies: 0
