I have been messing around with this rooting/flashing stuff long enough I thought I might give a go at learning more of the technical end of this and make a ROM. Before I even look into what is needed to learn this stuff I thought I would try and find out if my idea for a ROM is even worth doing in the first place.
I am wanting to make a ROM that turns the phone into a dedicated hotstop. Devote what memory is not used into a packet buffer and the SDcard into a network drive. Make the screen into a Network details monitor. If possible allow bluetooth to be used to manager the device remotely. A secondary objective it to try and keep it port-able because this to me seems like a good option for EOL devices.
Other than adding the above features the main goal is to increase throughput and increase connection speed/stability.
All this might be a pipe dream so I was hoping a dev here might be able to shed some light on the possibility of this even being in the realm of doable. I believe it will take alot of work to make such a major role change to an OV but in some areas it is simplifying things by just removing them. I am willing to devote months to the project so I am not taking this lightly.
