Results 1 to 22 of 22
Like Tree6Likes
  • 1 Post By ThatGuyLurkin
  • 2 Post By EarthnFire78
  • 2 Post By tvall
    Default [GUIDE] How I ported roms?
    How I Port Roms
    PREREQUISITES :
    * Base rom(CM7/CM9)
    *Rom you want to port(Must be MDPI I believe)
    *7-zip or Winrar
    OPTIONAL: APKtool if you want to fix MMS
    STEP 1:
    Open Base Rom,
    If CM7: Delete Apps, Framework, and Media
    if CM9: Delete Apps, Framework, and go INTO the media folder, delete everything but the EMD files.
    STEP 2:
    IF CM7:Copy Apps, Framework, and Media from Port, to Base
    IF CM9:Copy Apps, Framework, And audio folder.
    MIUI: Copy Everything in the media folder except EMD files
    STEP 3:
    Go into bin of both roms, Copy EVERYTHING from Base, to Port. Next, copy everything in Port to Base. This will fill in missing files.
    STEP 4:
    Go into etc/Init.d/ in both roms. Copy EVERYTHING from Base, to Port. Next, Copy everything in Port to Base.
    STEP 5:
    Go into etc/Permissions in both roms. Copy EVERYTHING from Base to Port, then Port to Base
    STEP 6:
    Go into etc of both roms. Copy other files(NOT FOLDERS) from Base to Port, then Port to base.
    STEP 7:
    Go to Lib of both roms. Copy all Lib files from Base to Port, then Port to Base.
    IF it's a special rom, you need some other files. (Search XDA if you get problems)
    STEP 8:
    Go into Xbin of both roms. Copy all from Base, to port. Then Port to Base.
    After those are done, you should be able to flash the BASE rom with no problem, and enjoy the ported rom.
    Post #2 will be Hotfixes(MMS, How to include Tweaks properly, etc)
    I'll add screenshots when I get a chance.
    Thanked by 11:
    + Show/Hide list of the thanked
    bokoxthexchocobo likes this.
  2. Thread Author  Thread Author    #2
    Default Re: [GUIDE] How I ported roms?
    Reserved
    Thanked by 2:
    Badboytoast likes this.
  3. #3
    Awesome thank you!!
  4. #4
    cpackar's Avatar
    Posts
    ROM
    BobZhome 9-1-2012
    Could I make my own fixes for like MMS, personal customizations with favorite roms, stuff like that?
    What do you mean by that? :P
    Second post will also have something I call " The Lazy Porter " xD
  6. #6
    cpackar's Avatar
    Posts
    ROM
    BobZhome 9-1-2012
    Quote Originally Posted by ThatGuyLurkin View Post
    I like to test like EVERY rom that comes out, and MMS doesn't work on some ports, and I want to learn to fix a bug if I see it.
  7. #7
    johnh02's Avatar
    Posts
    ROM
    quattrimus cm9
    Good guide thanks
  8. #8
    What do I use as a base?
    Any v rom I choose?
  9. #9
    A-android-B's Avatar
    Posts
    ROM
    it changes so much
    Thank you for your wisdom. You are far too kind.
    beamed from the mothership...
    but its only a proxy for my
    lubuntu 12.04
  10. #10
    johnh02's Avatar
    Posts
    ROM
    quattrimus cm9
    Quote Originally Posted by adamhos View Post
    Any v rom I choose?
    Yea any v rom that has at least mostly everything working
    Thanked by:
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by cpackar View Post
    You'll need APKtool to do so.
    If you use Windows, Extract files from
    apktool-install-windows-r04-brut1.tar.bz2
    apktool1.4.3.tar.bz2
    And put them in C:\Windows\
    Thanked by:
  12. #12
    EarthnFire78's Avatar
    YAY!!! ME :)
    Posts
    ROM
    Custom ROM & Kernel
    Here is a new version of , the project was taken over by iBotPeaches because Brut.all stopped development.
  13. #13
    What devices can you port from? Could I port to the Optimus Slider? Or port in from something like the Nexus to the OV? Are there limitations.
  14. Thread Author  Thread Author    #14
    Quote Originally Posted by EarthnFire78 View Post
    This explains sooooooo much! Now I can decompile systemui the right way for ICS!
    Quote Originally Posted by Sneaky_1 View Post
    You can attempt. Won't hurt. Stock based roms won't boot though.
    CM7, 9 or 10
    Sent from my HTC One V using Tapatalk 2
    Thanked by:
  15. #15
    tvall's Avatar
    Posts
    ROM
    cm9
    The nexus is an hdpi armv7 device. You can port, but you'll have to resize every single image to mdpi and recompile every single binary for armv6. And there will likely be some more issues too.
    Typically. When porting you stick with the same screen size and CPU instruction set. If you have an hdpi armv7 device, port from hdpi armv7 devices. If you have a tegra tablet, porting from other tegra tablets is easiest. If you have a crappy mdpi phone with an obsolete armv6 CPU, you know what to do.
    my roms & kernels (based on iho)
    If you'd like to donate to me, i accept litecoin, bitcoin, and hardware
    LTC - LTVALL5gsjPvgeiBWD7c6DHNWidbpzVu3w
    BTC - 1TVALLetFibDe8Zap5qPsqa4BAJWQYQ59
    Thanked by 3:
    cole2kb and A-android-B like this.
  16. #16
    Thanks guys. I was thinking of porting a nice cm7 ROM to the wife's Slider, but with no cm7 base ROMs, looks like its a no go.
  17. #17
    bunanson's Avatar
    Posts
    Global Posts
    52 Global Posts
    I have op V and op slider. And I have been waiting for some fun with slider. And... just waiting ; kind of interesting to see the huge difference between op V and op slider, where the slider is supposed to be the big brother, but not much custom ROMs.
    bun
  18. #18
    Posts
    ROM
    it changes so much
    Port from the v to the slider
    whatwasthat?
    lubuntu 12.04
  19. #19
    [Q] When you are copying from base to port, are you overwriting almost all of the files in the port folder with the base files? Or are you skipping?
  20. Thread Author  Thread Author    #20
    Writing Over. By doing so, it will fill in missing files if for apps. Like if your missing a lib for quickpic. It'll fill it in, and the app will work now
    Thanked by 2:
  21. #21
    Do you need permission to port someone's rom?
  22. #22
    johnh02's Avatar
    Posts
    ROM
    quattrimus cm9
    U only need permission if you want to release it
    Thanked by 2:
  1. [GUIDE] How to root, un-root and rom your Droid Incredible.
    By Brett in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 02-12-2013, 11:52 PM
  2. [GUIDE] How I port
    By rukin5197 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 07-18-2012, 08:16 PM
  3. [GUIDE] How to Port
    By thaunknownartist in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 05-08-2012, 10:11 PM
  4. [Sticky?] Newb guide -- How to root, recovery, and ROMs [Windows]
    By t0ast3d in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-20-2010, 01:19 AM
  5. Replies: 3
    Last Post: 05-19-2010, 05:37 PM
