[ROM] NOV-10-12 | ICySnap v1.0 PILOT | LGUI 3 | ICS 4.0.4 | SCOOP SOME ICE CREAM
Original Thread - [Only registered and activated users can see links. Click Here To Register...]
By Neko95
[indent]INTRO:
Hi and WELCOME, once again I present you my shared ROM, now that we are having stable builds of ICS (Android 4.0.4) I decided to move on it and give up on GingerBread, knowing mostly everyone knows about GingerSnap which will be the successor of this ROM i.e (ICy Snap). Know that we have an upgrade all same stuffs from before will be included on this, like my ui concept LGUI as usual, making mods improving system and get some snappiness, porting some goodies, and expect the unexpected so Good Luck and enjoy to everyone :good:
- Based off CM9 by TheKraven
- LG 3 User Interface Inspired (PATCHED ROM Fyi)
- LG 3.0 Launcher from L5 (Widget and icons automatically moves and fits on screen, same as in JB )
- LG 3.0 Weather Widget
- L7 Full UI, Notification, Ringtones Enhancements
- L7 Wallpapers, Fonts and Boot Animation
- Fancy Framework LG UI cosmetics
- Fancy UI animations from Jelly Bean
- Some Ported LG Apps From Optimus L7 (More soon)
- BootSound support on ICS
- System Optimizer Featuring ICy Tweaker
- Improved LMK Mem and OOM grouping
- Enabled linux SWAP for advance users, Expanded memory
- Increase sd read/write and throughput
- VM and Kernel management for Battery conservation and performance enhancement
- Miscellaneous UI and system improvement
- Pre Configured ROM, YES you'll get MY settings AS DEFAULT
- Nothing much to say, Get the experience out off it;)
- Working OMX HQ video playback
- DSP Manager YES play music and press menu button select equalizer
- Some Ported apps from L705 firmware
- LG UI Holo Dark Including some pre apps, Not HOLO LIGHT UI, but Im working on it (halfway)
- NO GAPPS Installed, Added separate GAPPS on download section
- Problems locating your current position? Flash Gapps
- NO Theme.apk, This is a Patched ROM
- aLogcat app, so newbies can monitor and send logcats, see Guides how to enable logcat 1st
- NO Fee's IT's FREE
[indent]▷TERMINAL EMULATOR COMMANDS
[indent]
TAKE NOTE! ALL COMMANDS WILL ONLY WORK BY TYPING "su" (W/O QUOTATIONS) 1ST
[indent]
▷TO ENABLE OR DISABLE BOOT SOUND
▷TYPE: "bootfxoff" TO DISABLE
▷TYPE: "bootfxon" TO ENABLE
FYI, SCRIPT IS UPDATED, IT GIVES YOU OPTION TO CHANGE BOOT SOUND
EASILY BY DISABLING BOOT SOUND IT WILL MOVE "android_aduo.mp3"
TO YOUR SD CARD ROOT, NOW BY REPLACING IT WITH ANY SOUND YOU LIKE
Personally, I have never tested these commands, so it's all you guys. :P
*Uploading*
Tapatalk won't let me. :(
Re: [ROM] NOV-10-12 | ICySnap v1.0 PILOT | LGUI 3 | ICS 4.0.4 | SCOOP SOME ICE CREAM
▷PILOT version 1.0
[B]See ROM features
ICyTweaker for this ROM, see ROM features
Reverted the dalvik cache to data patch, could fix the random reboots while browsing
- Download ROM.zip copy to sdcard
- Reboot to recovery
- MUST wipe data, dalvik-cache, system, sdext
- Flash the ROM and wait for the installation to finish
- Reboot and Enjoy ICySnap
Last One.
Sent from my HTC One V using Tapatalk 2
][Only registered and activated users can see links. Click Here To Register...]
- The Kraven for the based ROM
- TheKraven for the Kernel
- Neko for the ron
- LG for the resources
- Google for references
- Cyanogenmod
- TheKraven, Rukin, Sellers, Cole, and another members
- Everyone or thing, else I forgot
Cant wait to try it out
Links up!
Disable Notification indicator for better UI. :thumbup:
Quote:
Links up!
Thanks downloading now!!:D
So far its pretty smooth
Any way to change the carrier name?
If CM doesnt have the Settings in it, you need HDD Hex Editor.and edit Eri.xml in Framework-res.apk
Runs real smooth :) good job tgl!! :):):)
HQ video don't work for me.
Yes. That's broken. I never tried it on the rom though. Ism where the files originally is, but ill try again.
Is it just user error, or does the home key not work for anyone else?
Besides that, this is a great port. Smooth like butter.
Did you flash Gapps?
Yeah, it wound up being a bad flash. All is working smoothly now.
So glad to see someone using theKraven's ics as a base for a new rom! Plus a new version of 'snap! Gonna try this out asap! I've never used three exclamation points in a row before, sorry.
So wait, HQ video isn't working yet?
First impression: awesome! I love the animations. Taskbar is kinda cool. I can't seem to find the launcher options, I'd like to cut down to 3 home screens and hide icon labels. Idk if i missed that somewhere. Weather widget is really nice. So glad you used theKraven's ics as a base.
Thanks so much for this! Really great job!
Sent from my GT-P7310 using Android Central Forums
It's great running smooth, only thing is i keep getting "Error retrieving information from server" everytime i try to do anything with google play, tried reflashing GAPPS, not sure how to fix. Otherwise everything else is great takes a bit getting used to.
*****RESOLVED*****
Must of been bad install, re-installed ROM and Gapps again and all is working fine now.
Pinch the screen to see your home screens
1 Attachment(s)
I'll try to see what broke HQ. Could be multiple files, or just me doing something wrong.
Rom has Black in Black in some places, and Launcher force closes on reboot, or rotation.
Also, launcher is 5 dock, feel free to fill it ;)
I can't get gapps installed at all. :( . I even tried installing the Play Store apk and it force closes!!!! :-!
Try the one in OP.
