VM670 stuck in bootloop
Nov 11, 2012
15
Ok so I factory reset my phone, and now its stuck in a bootloop, i can select things and navigate the menus in Clockworkmod recovery 5.0.2.7, i even have given a try at ADB commands and stuff, nothing works (yes i am a noob at this) I cant get any numbers to pop up for my phone, and i deleted the original ROM for it. :( I didnt mean too. But anyways i want a simple guide with instructions on how to fix this, step-by-step would be nice, and maybe some pictures. I know this is asking for a lot.
Also it wont let me flash any other ROM I either get error 7, or signature failed. :(
So please help me, i need my phone and im out of town.
thewraith420
1,987
223
63
First things first.. Did you use rom manager to get that recovery?
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
Nov 11, 2012
15
I would believe so, but it's been so long. I'm like 90% yes I did use rom manager.
- - - Updated - - -
upconvert
486
3
That's probably the root of your problem. Rom manager has messed up more phones on this forum than naomi cambell. Flash a new recovery. You can find several on this forum. If you want a basic no frills cwm, I recommend BobZhome's. Once you get that working, you should have no problem flashing a from.
upconvert
486
3
In the stickies, it's called simplified root, recovery and rom. Skip to step 4.
Sent from my GT-P7310 using Android Central Forums
