Results 1 to 15 of 15
- 11-13-2012, 06:10 PM
Thread Author #1
Help with seemingly endless brick problems
Hey guys, I volunteered to help my buddy out and unbrick his OV. He has not told me what he did to it, but it is bricked. When you power it on, it displays the LG logo, and then the screen goes black. When I power it into recovery, the volume down button makes the selection choice go up, and the voice command button makes it go down. When I press the camera button (like I want to select something) it just flashes the main recovery screen at me. It will not let me select anything, and it won't boot into the rom. I will keep this updated with information as he gives it to me, but does anybody know what I could do?
- 11-13-2012, 08:02 PM #2
- 11-13-2012, 09:39 PM #3
- 11-14-2012, 05:51 AM #4
- 11-14-2012, 01:01 PM #5
- 11-15-2012, 03:55 PM
Thread Author #6
Re: Help with seemingly endless brick problems
Lets see... i rooted it, then i installed a few root apps, worked perfectly, installed a stock overclock Rom, worked as well, but the Google apps weren't there. (Which annoyed me for some reason) so i tried a new Rom (don't remember which, but i did it just because) like a smart router, i chose to make a backup with clockworkmod, then, i installed it. Black screen. So, i attempted to recover my stock Rom and overlooks Rom, but both were gone (?) And that's about it. Oh, and after the recoveries were gone, i did a factory reset, then tried to reinstall the Rom i had before (after the overclock) and it wouldn't install. Theni turned it over to you.
This is some more information he sent me about what he did. And how would I go about flashing a new recovery through adb? I thought that was something in settings you turned on, but I cant get any part of this to work. And I did try pressing all the buttons, as I figured he may have messed up the mapping, but none of them were able to select anything :/ Thanks for your guys' input so far - 11-15-2012, 04:03 PM #7
- 11-15-2012, 04:14 PM #8
There are good instructions in the stickies, called simplified root, recovery and rom. Skip to step 4, but instead of the cwm recovery in that post use one of the recoveries that theexile1 mentioned above. Once you get the recovery installed, choose the fix bootloop option, install the new rom, install the gapps, then reboot.
- 11-15-2012, 04:37 PM #9
- 11-15-2012, 05:24 PM
Thread Author #10
- 11-15-2012, 05:54 PM #11
- 11-15-2012, 08:17 PM
Thread Author #12
- 11-15-2012, 09:24 PM #13
I have used droid@screen before, and it works well. You need to have vm670 drivers from LG, java, and the adk. What type of pc are you using, and why do you want to run it off a flash drive?
Sent from my GT-P7310 using Android Central Forums - 11-18-2012, 06:19 PM
Thread Author #14
- 11-18-2012, 06:29 PM #15
need help with my nexus s problems
By thejedimex in forum T-Mobile Nexus SReplies: 2Last Post: 02-05-2011, 01:38 AM -
Looking for help with a Kernel problem. Rom devs and kernel experts welcome to look
By Trust in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 3Last Post: 12-07-2010, 09:35 AM -
Help with Vonage and EVO - Strange Problem
By kitarkus in forum HTC EVO 4GReplies: 8Last Post: 09-03-2010, 12:44 PM -
can someone help me with a basic android problem?
By rem_kujawa in forum HTC EVO 4GReplies: 3Last Post: 07-07-2010, 08:12 PM -
Help with web link - Is it a problem with phone?
By totaled in forum HTC EVO 4GReplies: 7Last Post: 06-22-2010, 09:57 AM
Reply
