- 11-14-2012, 05:59 PM
Thread Author #1
- 11-14-2012, 06:17 PM #2
Re: VM670 rom help
In CWM, after doing a nandroid backup, wipe cache, dalvik cache, boot, system, and data. DO NOT WIPE SD-CARD. Using CWM reinstall ROM zip file then reinstall GAPPS. Reboot and you should be okay.
You can also try reinstall without wiping anything to see if that helps. If not you may need a different recovery. You stated CWM but exactly which recovery are you using? Knowing this will also allow us to help you.
Sent from my LG-VM670 - 11-14-2012, 06:23 PM
Thread Author #3
Re: VM670 rom help
Dont know im a noob at this, i reset my phone from factory and then got stuck in the CWM screen, read a little and found a rom to flash, my sd card is clean except for the ROM, GAPPS and the .img file for the ROM, I can flash the rom it say sucessful and enjoy, then install gapps from the install from zip menu. Then i tried reboot, and it still returns to the screen.
- 11-14-2012, 06:35 PM #4
Re: VM670 rom help
You may need a different recovery to fix bootloops maybe COT or TWRP
I will look for a link.
Just to confirm you did not use ROM Manager. It does not work for our phones. Also never do factory reset from any custom ROM. You can safely reset from in recovery but not from the ROM.
I will PM link once found.
Sent from my LG-VM670 - 11-14-2012, 08:33 PM
Thread Author #5
Re: VM670 rom help
Tried still doesn't work won't even flash without errors. And I have tried several. I'm just wanting to get basic functions. Wished I would have never made the switch from apple. Yes I said apple I loved my iPhone and hate my droid. And I've had several different ones.
- 11-14-2012, 08:55 PM #6
Re: VM670 rom help
Now, now. I'm gonna assume you're just blowing off steam, and you didn't mean the mean things you said. Once you get it working right, you may grow to love android.
You might need to flash a different recovery like xonia or cot, which have an option to fix the bootloop, then flash the rom and gapps. Since your recovery seems to be somewhat functional, you can try flashing through there. If that doesn't work, you'll have to try the adb method from the stickies.
Sent from my GT-P7310 using Android Central ForumsLast edited by upconvert; 11-15-2012 at 04:17 PM.
- 11-15-2012, 01:09 AM #7
Re: VM670 rom help
- 11-16-2012, 12:14 PM
Thread Author #8
- 11-16-2012, 01:31 PM #9
- 11-16-2012, 05:12 PM #10
Re: VM670 rom help
Flashing a rom shouldn't be able to take out your recovery under any circumstances. Unplug from usb-remove battery-reinsert battery-hold home/volume down/and power to attempt to boot recovery
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
Rom Manager / Backup Rom Help
By dsmith1069 in forum Verizon FascinateReplies: 4Last Post: 10-16-2010, 11:48 PM -
Vaelpak Rom Help
By chadrenshaw in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 15Last Post: 09-25-2010, 07:40 PM -
How to Install Roms help!!!
By Bizzare in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 11Last Post: 09-21-2010, 04:33 PM -
New to root, Baked Snack Rom...Help!!
By pdiddyfan in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 5Last Post: 09-20-2010, 09:18 PM -
Theme/ROM Help & Questions
By zeravla531 in forum HTC Hero Rooting, ROMs, and HacksReplies: 14Last Post: 02-27-2010, 03:04 AM
i cant go back to my old rom it got deleted with my backup and everything. So now my question is what to do from here? I tried rebooting, and power off, pulling the battery and everything im still stuck in CWM and i cant get out of it. So please help im a noob
Reply
