Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By fightu35
    Default Please help,stuck in recovery !
    Hey guys ok heres what happen ,LG OPTIMUS V I rooted it everything worked rooted,I think my brother did a factory reset while rooted,now I cant turn my phone off !! every time it starts back up it goes into the recovery, I see the android recovery screen but I can not chose any options it just resets all and I lose everything ! any help would be great guys now its not rooted any help would be great !!
  2. #2
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    Default Re: Please help,stuck in recovery !
    In the stickies, read LeslieAnn 's optimus v reference guide. She has links in there to threads about your problem.
    Sent from my GT-P7310 using Android Central Forums
  3. #3
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    You need to flash xionia or COT recovery and use the fix boot loop option.
    Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
    "You need to flash xionia or COT recovery and use the fix boot loop option"
    thank you for your reply,I am new with this stuff,my friend kinda rooted my cell then messed it up for me to fix.
    Im not sure what you mean..
  5. #5
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    A custom recovery is software for your phone that allows you to make changes to it without fully booting up the operating system (or rom). xionia and cannibal open touch are two custom recoveries that have a "fix bootloop" option, which will help you solve your issue, and let you install a new rom.
    Since you are new to this I highly recommend reading all the way through LeslieAnn's reference guide in the stickies. It is very well written, and will answer questions you didn't even know you had. She has also included three links to methods to fix your exact problem.
    Quote Originally Posted by upconvert View Post
    thank u so much for the reply,I believe I found her posts..any idea which topics I should start with..I shall read anything I need..thank u again
    upconvert likes this.
  7. #7
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    No problem. I love it when people want to read! Start with this one...
    [GUIDE] 2012 Optimus V Reference Guide (Start here!)
  8. Thread Author  Thread Author    #8
    thank you..to be a little more clear,I heard of root..so I did not,I know nothing else..lol I got super user..then gingerbreak then bam I had a rooted phone played around no if I shut my cell off everytime it starts back up all is reset I see the the android recover screen in yellow,I have no options and my cell restarts with all wiped out any help from anyone would be great ..off to read I go thank you again also I have no problem with learning but can you at least tell me what do u call what I did to my phone...seems I hit reset my phone using privacy..so I bricked it ?
  9. #9
    Posts
    ROM
    Changes Daily
    Quote Originally Posted by fightu35 View Post
    Recovery bootloop. Privacy menu factory reset is a common noob mistake. It's not really bricked but requires a bit more fiddling around to fix
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by thewraith420 View Post
    thank you...so its called bootloop...where should I start ! reading Iove but where to start gives me a headache
  11. #11
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    In LeslieAnn's guide there are 3 links under the section about how to recover from the factory reset.
  12. #12
    If your rom is working
    Download and install “flash image gui“ here:
    then download xonia recovery :
    Open flash image gui
    Click recovery
    Click browse
    Go to your sd/ download folder
    Find the xonia recovery img you just downloded
    Install it
    When youre done shut your phone off and boot into recovery by holding home, volume down, and power
    You should be in xonia recovery
    Find the bootloop fix option (i think its under advanced)
    That should fix your bootloop
    I would recommend wiping your phone and and doing a factory reset (IN RECOVERY ONLY)
    And youll probably wanna go ahead and read this and flash a new rom
    [HOW-TO] Simplified Root + Recovery + Custom ROM
  1. Please help,stuck in recovery !
    By fightu35 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 11-19-2012, 04:42 PM
  2. HELP! Stuck in Recovery & home screen is unresponsive
    By 627gigi in forum Sprint Epic 4G
    Last Post: 06-27-2012, 10:58 PM
  3. PLEASE HELP! Stuck in CWM Bootloop
    By IDontHack in forum LG Optimus S
    Last Post: 05-05-2012, 07:27 AM
  4. Please help! im stuck in recovery mode.
    By cusco in forum Verizon Droid Incredible
    Last Post: 09-24-2010, 04:01 PM
  5. Stuck in recovery - please help
    By levjoy in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-30-2010, 09:25 AM
