Results 1 to 10 of 10
- 11-27-2012, 10:46 PM
Thread Author #1
Cai From Help
So on alpha 18 c and alpha 19e even the kravens paranoid android from when I get to like 70% baterry my phone reboots and wont turn it just keeps rebooting until I charge it psst 70% and turn it on while plugged into the charger any help will be appreciated
Sent from my LG-VM670 using Tapatalk 2 - 11-28-2012, 02:15 AM #2
- 11-28-2012, 09:42 AM
Thread Author #3
- 11-28-2012, 10:20 AM #4
Re: Cai From Help
I'm not sure about the specifics for twrp, just make sure you wipe boot, data, cache, system, sd-ext, and dalvik cache. Also, you could try fully charging your battery, then deleting the battery statistics from your recovery. Then run the battery all the way down before you charge it again. I've seen it work on my tablet, but I've never had to try on this phone, but it couldn't hurt.
btw, my phone autocorrects "rom" to "from" all the time, too.Last edited by upconvert; 11-28-2012 at 11:02 AM.
- 11-28-2012, 12:13 PM
Thread Author #5
- 11-28-2012, 05:57 PM #6
Re: Cai From Help
Full wipe is aka factory reset--it's in both twrp and CM recoveries and probably others as well
I tried out this ROM for maybe 4 days looked really well done to say the least!
Flashed it using CMR....fine to use...
just was missing some features I would like put in (portable hotspot) so had to revert back. Used twrp recovery then to flash /wipe to previous ROMSent via my ZV5 VMOV(ns) - 11-30-2012, 01:14 AM #7
- 11-30-2012, 08:52 AM #8
Re: Cai From Help
When I do a full wipe I wipe:
wipe data/factory reset
wipe cache partition
wipe dalvik cache (advanced section)
format boot, system, data, and cache (mounts and storage section)
When done with that I select obijohn's update_wiper_1.3.zip that I put on the SD card.
When done, there is absolutely no residual data left to corrupt the new ROM or a backup.
Sent from my LG-VM670 using Android Central Forums - 11-30-2012, 12:21 PM
Thread Author #9
- 11-30-2012, 12:36 PM #10
Updating from 1.0, help!
By midnite#ac in forum HTC HeroReplies: 5Last Post: 02-12-2010, 03:07 PM -
Help to delete an account from combined inbox
By Tomadoggy in forum Motorola DroidReplies: 3Last Post: 12-04-2009, 12:43 PM -
New from Blackberry - Notifications Help
By wwwdeveloper in forum Motorola DroidReplies: 13Last Post: 11-18-2009, 08:27 AM -
Need help from my fellow Droiders.
By nursescott in forum Motorola DroidReplies: 14Last Post: 11-10-2009, 04:16 PM -
SOS: Please Help: IMport SMS from XML file to G1
By android007 in forum General Help and How ToReplies: 0Last Post: 02-06-2009, 11:15 AM
Reply
