DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By adamhos
    Jen Matthews's Avatar
    Posts
    ROM
    2.6.32.9
    Question Help? LG Optimus S through Virgin Mobile
    I've had my phone since March,
    I WISH this thing had more memory but otherwise I love it.
    Sometimes it freezes, but I think I've figured out that it did that because I had too much on it.
    I end up having to pick what apps I REALLY want, and what I can live with out.
    Virgin has so many apps on here that I don't use. I'd like to root this, but I'm a little afraid to. I don't want to brick my phone.
    Aside from the above, today the touch screen started acting up. First it acted strange, then it stopped working all together. I pulled the battery and let it sit for a half hour. When I turned it back on the touch screen is working, but seems off... like it needs calibrated? (If that's even possible)
    Here's the technical info on my phone.
    Anrid erion 2.2.2
    Basbnd Verion VM670ZV5_60401001
    Kernel vesion 2.6.32.9
    SW Version VM670ZV5
    HW version 1.2
    Any help would be greatly appreciated.
    Oh, I've also ready you can only ROOT if you have windows 7. Is that true?
    I'm still on XP. Is there a way to do it with XP?
    Thnk!
    ~Jen
  2. #2
    williek113's Avatar
    Posts
    ROM
    CM7/CM9
    Default Re: Help? LG Optimus S through Virgin Mobile
    WEEELLLLLLL, since you're still on froyo, just download "gingerbreak 1.2" from the browser on your phone. This is what I always use. I've never had a problem with this ever. Once its downloaded tap on the finished download and install it. Open it up, tap root after following the on screen instructions, and it should reboot and you're done! You should have Superuser. That means you're rooted.
    Sent from my LG-LS670 using Android Central Forums
    I can't seem to stay on the same rom for longer than... a day... sent from my LS670, or my windows 7 computer
  3. #3
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    ^--What he said. I'd like to add.... This site has an optimus v section that this should be posted in. The 2 phones are for the most part the same but the VM670 guys will know the virgin software better
    Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
  4. #4
    upconvert's Avatar
    Posts
    ROM
    Cold as Ice
    ... and welcome to the optimus v section. They are right, gingerbreak is the way to go. Check out the stickies in this forum, especially LeslieAnn's ov reference guide, and the one called simplified root Rom and recovery. Everything you need is there. If you get stuck, just ask. There's lots of helpful people here.
    Sent from my GT-P7310 using Android Central Forums
    Posts
    ROM
    2.6.32.9
    THANKS!
    It almost seems like it's too easy. lol
    This will enable me to remove the stupid software Virgin has on the phone?
  6. #6
    Quote Originally Posted by Jen Matthews View Post
    THANKS!
    It is very easy
    I would suggest installing a custom recovery menu
    Then you can backup and wipe your phone, then flash a custom rom...it‘ll bring the best out of your phone
    Follow this guide and youll be golden
    [HOW-TO] Simplified Root + Recovery + Custom ROM
    Posts
    ROM
    2.6.32.9
    Thanks!
  8. Thread Author  Thread Author    #8
    Posts
    ROM
    2.6.32.9
    I am so nervous about doing this. If I screw up... I'm screwed. I NEED my phone for work. UGH!
    Anxiety.
  9. #9
    Anxiety.
    I would set aside an hr or 2 that you dont need your phone
    If you screw it up it can be fixed, but if you follow that guide you should have no issues
    Backup your sd to a pc first
    Then once you root and install a custom recovery, you can backup your phone
    Just dont rush and youll be fine
    bkttk2 likes this.
  1. LG Optimus V by Virgin Mobile
    By andel7539 in forum Sold / Archived Marketplace Threads
    Last Post: 06-07-2012, 09:06 PM
  2. jar applications on a lg optimus v from virgin mobile ?
    By miguel760 in forum Virgin Mobile Optimus V
    Last Post: 05-06-2012, 12:44 PM
  3. Would liek to root the LG Optimus V (from virgin mobile)
    By droid4life2012ME in forum General Help and How To
    Last Post: 08-03-2011, 01:57 AM
  4. [HELP!] LG Optimus S with broken recovery?
    By chronostorm in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 03-12-2011, 08:49 PM
