- 12-02-2012, 02:33 AM
Thread Author #1
Optimus V - Not Charging on Attempted Upgrades to ICS and JB using BobZHome's ROMs
Hey Everyone!
I'm kind of a n00b, so I apologize. I tried looking around but wonder if I'm a strange one off case. I know a few people have had issues with batteries charging really slow and it might have been a ton of apps running in the background, bad cables, etc...
Going to try to get as detailed as possible and spin a bit of a yarn, in an effort to kill off any solutions I've tried already...
First off, I've had this phone for quite awhile. For the first few months, I didn't even use the USB Cable they gave me (relied on the Wall Charger instead) only to find out way too late that for some really irritating reason, it doesn't get recognized as a USB device. I've tried different cables (that have worked with other devices) and different machines (three different PCs (2 Running Windows, 1 Running Ubuntu), and a Mac). It was a very odd type of irritating knowing that a charge can run down the cable, but not data for some reason (and I've tried all of the USB Debugging toggle business). I had all but given up on the prospect of doing fun things like rooting my phone until I ran into the likes of Gingerbreak and went down that road. Even after that, I delayed awhile before I ventured into messing with ROMs... which started last night.
Excited at the idea of running Jelly Bean on this phone that feels like it's been on its last legs, I read (and re-read) all of the instructions. I went out and purchased an 8gb MicroSD card to setup one of these fancy sd-ext partitions. I had ClockworkMod already running from my previous forays into invalidating any warranty that may have still stuck around and wiped and rewiped and formatted everything. I first tried using Clockwork to create the partition on the card (1gb if you're wondering, 0 swap) and kept getting errors about not being able to mount it. Frustrated and remembering my laptop has an SD Slot, I threw it on, used gparted and changed it into an ext3 partition (versus the 4, which I might have erroneously read somewhere may be a culprit with some ROMs or apps or whathaveyou. Apparently it only kind of matters and probably isn't my issue here...)
I trudged forward, having downloaded the ROMs and modified GApps from Bob's links from his site. I Flashed both, I rebooted, I waited...
Beautiful, hypnotic boot screen. Wasn't as long as Bob's own estimate (8 minutes he says? Mine got okay around 5!). I was customizing, downloading apps that I normally couldn't due to a very low version before. I was playing, having fun...
Then the battery warning came on. I need to plug it in... but it is plugged in. Hrm. Tried the Wall Charger... again, battery kept dwindling, no lightning bolt. Telling me to plug the damn thing it. It IS in!!
Frustrated, rebooted, and rebooted. Learned that if it's plugged in and you tell it to Power Off, this ROM will do a full reboot (instead of the stock charging-only screen) if it's plugged in. So it just went back to the Login screen telling me to plug it in.
But if I Powered it off Unplugged, it would NOT do it. Weird, right?
So I rebooted into recovery mode (which involved me powering off unplugged... the Reboot into Recovery option didn't seem to work for me...) and plugged it in there. I even tried wiping the Battery Cache thing. After waiting a bit, booted up like normal... IT TOOK SOME OF THE CHARGE! But then continued to complain and wouldn't eat it's tasty meal-o-bolts.
I gave up. I restored my previous installation (like all the guides told me to do with Nandroid)... waited for the old screen I grew sick of... and... charging works. Battery, everything.
Maybe... MAYBE it was just for CM10? It is considered Alpha, no? Maybe I'll have better luck with CM9?
Nope. Same issue.
Anyone have any ideas? Does Android 4+ check for some USB thing before allowing it to charge? How does it handle Wall Chargers? Should I try someone else's ROM? Is there a place I can poke around on my phone to give up some more clues and maybe (gasp) even figure out why the hell my USB Cable doesn't work in general for data?
I'm desperate guys. Please bestow wisdom and knowledge upon me! Thank you!
UPDATE: So while playing with ics, I had it plugged in via USB cable and though even on the Battery Screen under Settings it said "Discharging", I refreshed and the time left before it going kaput went up by a mere seconds! Going to try jb again and see if something similar happens...
UPDATE 2: Apparently, I'm an ***** and can't read. That was just telling me how long I've been using the battery. I'm at 2% right now, going to shut it off and try again in the morning, hopefully with enough juice to try any solutions anyone may have?Last edited by hapworth; 12-02-2012 at 02:52 AM. Reason: Err nevermind...
- 12-02-2012, 08:59 AM #2
Re: Optimus V - Not Charging on Attempted Upgrades to ICS and JB using BobZHome's ROMs
bad usb cable? there are two types of the wall charger. one is the plain wall charger. the other is a wall charger, but it comes with the plug head and a USB connector at the bottom. If you have that, try that and see what happens. If nothing, you got a bad usb cable.
And as far as USB mass storage. On Bob's CM9, you have to also enable "ADB over Network" in Debugging...for me I didn't have to when I connected it to an ancient XP machine, but had to on Windows 7 and 8. On CM10, it's hit or miss. I can't do it on mine, I'm sure others can. ADB over Network has to be enabled too. - 12-02-2012, 10:07 AM
Thread Author #3
Hey atrain,
I've tried several different cables... I only have straight USB Cables or a Charger... as in not a plain USB cable that has an attachment for the wall...
I've tried at least 3 different USB Cables... all of which I regularly use with other devices and they work perfectly (A Kobo Touch, the USB Cable that came with my Optimus V, another I had lying around from an old External HD). I've tried all of these plugged into a Desktop running XP, and a Laptop running Ubuntu.
As for Chargers, I've used the one that came with my phone, another for my friend's Kindle Fire, and another for my niece's Samsung Galaxy S3.
All of these charge fine with the stock ROM but none work for data. Nothing "sees" the phone. Nothing AT ALL (Charging and Data) works on CM9/10...
Again, n00b here... how can ADB help me? What would I be looking for?
Repeat though, I've pretty much given up all hope for using the USB Connection for Data. I just want to know if I can have either CM9/10 and have it charge. That would be more than enough for me. If any of these also jars the data back into working, that would be amazing but again... not necessary!
Thanks. - 12-02-2012, 11:46 AM #4
Hmm, same thing happened to me on every CM7.2 ROM, I tried them all and none of them would charge, but I flashed Bobz ICS ROM and it worked, and right now I'm on Bobz CM10 and charging is fine, maybe revert back to your backup and fully charge it and try a different rom like CM9 or CM7.2 to see if it works
Sent from my LG-VM670 using Xparent Cyan Tapatalk 2 - 12-02-2012, 11:52 AM #5
- 12-02-2012, 11:54 AM #6
- 12-02-2012, 12:16 PM
Thread Author #7
Hey atrain,
Thanks for the quick reply! A quick note of clarification, I've NEVER been able to get my Optimus V to connect with a computer via USB Cables. I don't own a Mac and mostly run either Ubuntu or XP boxes. I tried installing the drivers from LG in the past but... no machine seems to see it!
So to clarify, are you saying that despite nothing being able to see my phone (even on the stock ROM, straight outta the box), this has a chance of reviving it?
I'm currently on the move now, just want to know if it's worth a shot or likely to be a waste of time. Was this a solution to a bug my phone has been experiencing that others may have run into? (I haven't been able to find anyone else with this specific issue, unfortunately).
Thanks!
- 12-02-2012, 12:18 PM
Thread Author #8
alexkta,
Thanks for the input and man, is this frustrating or what! I will give this a shot when I have an hour or two to kill soon. Currently on the move. Thanks for the input!
I wish there was a way to pinpoint what exactly is going on. Like, if I were to post some logs or something (from somewhere?) will I be able to get some more insight from the class?
Thanks!
- 12-02-2012, 08:46 PM #9
Hey,
you are not crazy, you're not alone, it is unlikely that it is your charger/cable [you'll get lots of reply about that because people just want to help out]. I had the same problems back in June-Aug 2012 trying to flash the Quattrimus 4.0 ROM. It did not work in any mode, on or off etc. I could only charge it in stock 2.2 ROM (still using that) and in some other 2.x custom ROMs. A small number of others reported to have the same problem, but not enough to catch any attention. Eventually, after heaps of very serious troubleshooting, I gave up. I don't have a solution, but still hope that someone with low-level driver/kernel knowledge can have a look at this or at least give some intelligent feedback.
Have a look at my Post #2892 in thread '[ROM][BETA] Quattrimus ICS' and make sure to follow by links back to my original post, because there you find a lot of details.
To solve this, my only suggestion is to start collecting exact phone details from people experiencing this problem. - 12-02-2012, 10:18 PM #10
- 12-03-2012, 07:49 AM #11
as you noticed earlier, if all else fails and you still want to use the rom, charging should work ok in recovery. you just don't get a meter.
|..................................| - 12-03-2012, 12:47 PM #12
Can you confirm verbatim details on which Recovery you can charge your LG Optimus V? That would help us with troubleshooting, because, at least for me, which has the same no-charging problems as in the OP, can *not* charge in recovery. I have tested with Cannibal Open Touch v1.2 (also tried with ClockworkMod v3.2.0.1 and Xionia CWMA v1.2518.6). See Post #7384 (thread 'ARCHIVED: [ROM][ALPHA] quattrimus ICS'). The only way to charge is to flash back the stock ROM (or a few other Android 2.x custom ROMs).
Just to clarify: I am aware that there is no charge bar in most recoveries, but even so, the phone does not charge; it does indeed discharge even when plugged in and in recovery. - 12-05-2012, 02:02 PM #13
hmmm.
cannibal and xionia are optimus s recoveries.
i actually use ported p500 recoveries i stuck a stock optimus v recovery kernel into.
in the op of the blackscreen sticky are a couple recoveries patched with the same stock kernel if you want to test.
your usb port on the phone might be defective too.....**.../\…•^•…/\...**....
|..................................| - 12-05-2012, 09:14 PM #14
I've had this problem once, on a Rom I was testing out. In the end, it was the rom causing it not to be recognized.
Lol try mirage as suggested above. It really is an awesome rom. Personally I like Gingersnap 2.3, but when TGL finishes fixing the bugs (if he ever does) IcySnap, I will definitely upgrade!
As for recoveries, I never had a problem with TeamWins's Recovery Project. Its been ported to the OV. Its the best Noob friendly full touch recovery out there. - 01-06-2013, 08:21 PM #15
just thought I would jump in to say I am one of the people who had this same problem. I never found a fix and I just stuck with 7.2 with the ics theme. It works okay but after having a nexus 7 with JB I would really love to have ICS but doubt it will ever happen.
- 01-22-2013, 04:37 AM #16
Hey man. I think I might have a permanent solution for you. I am in your exact situation and completely sympathize with you. What I've learned how to do is to just purchase a separate battery charger (portable) and spare batteries. This way, your phone's charging issue is completely eliminated because you're charging the battery separately. Look on Amazon and research good portable battery chargers and lg ov batteries. As for data transfer, mac or not, purchase or rip Dropspot from the market. Free version is limited to 5 mbs giving/receiving. Hope this seriously helps.
Sent from my LG-VM670 using Android Central Forums - 01-22-2013, 05:03 AM #17
Check this out on AMZN:
Anker 2 x 1600mAh Li-ion Batteries for Compatible Models + Free Anker Multi-purpose USB Travel Charger
http://www.amazon.com/dp/B005B3L6KY/...idcentral00-20
PERFECT FOR YOUR SITUATION.
Anyone upgrade to ICS and keep their root?
By reyxlp in forum RAZR Rooting, ROMs, and HacksReplies: 2Last Post: 06-25-2012, 05:25 PM -
If you upgraded to ICS and you use pin code in google market
By xoomer1 in forum Motorola XoomReplies: 1Last Post: 06-11-2012, 02:49 PM -
Text to speech not turning off after upgrade to 2.2
By ewingman in forum General Help and How ToReplies: 0Last Post: 05-09-2011, 09:35 PM -
Bluetooth not turning on after upgrade to 2.2
By vmilan in forum Motorola Droid XReplies: 2Last Post: 10-10-2010, 11:20 AM -
N1 does not boot up after upgrade to Froyo
By cdupadhyay in forum Google / HTC Nexus OneReplies: 9Last Post: 07-03-2010, 02:15 PM
Reply
