Results 1 to 10 of 10
    Default Messed up SD card after using MiniTool Partition Wizard
    So I'm not sure what exactly I did, but I screwed up my SD card royaly!
    I was trying to format it to work with Links2SD, but was being wonky about it, and somehow ended up messing up the SD card. Phone simply says "Removed SD Card: SD Card Removed. Insert a new one."
    In Recovery (I have CWM v1.2518.4), if I go to mount sd card, I get "E:Can't mount /dev/block/mmcblk0.. invalid argument, error mounting SDCard." Same with formatting SD card, I get "Error mounting /sdcard/!"
    When I hook up my phone to the computer, and go to mount USB storage in Recovery, the computer seems to see it. I have a mac (I was using a borrowed computer when I ran minitool partition wizard), and under Disk Utility the SD card shows up. Weirdly though, it shows up as 7GB when really it is 16. I've tried reformatting it into two FAT32 partitions (which I think is what it was before when I was using it properly), but still when I reset, phone doesn't see it.
    Recovering data isn't an issue - I backed up before fiddling. I just want to know if I'm out of an SD card, or if there is still hope.
    Thanks!
    -Megan
    (P.S. - I have Optimus V flashed with Harmonia 2 )
  2. #2
    Default Re: Messed up SD card after using MiniTool Partition Wizard
    From my experience you are gonna need to use a card reader and wipe all partitions using mini partition tool
    I think you can do this in the disk management built in to some windows( not sure which ones but pretty sure xp has it)
    Then you will need to reformat the card and set up your partitions again
    Sent from my HTC 3VO
    Thanks for the advice Adam. But when I tried to fix the card in mini partition tool, it wouldn't let me do anything - it just said "bad disk" and didn't give me any options to re-partition (everything greyed out).
  4. #4
    If its in the phone it won't work if its f'd up
    You need to use a card reader....or get a new sd
    OK, will do. I'll report back w/ results.
  6. #6
    AndyOpie150's Avatar
    Posts
    ROM
    MiRaGe ROM
    FYI
    If anybody else messes up their SD card using Mini Tool Partiton Wizard, either trying to partition or by using one of the wipe options, there is a utility program called BootIt that will straighten everything out and allow you to use your SD card in your phone again. Follow the prompts and agree to everything. When finished put card in phone and choose the "erase SD card" option in settings/storage then reboot phone. BootIt worked on my 8GB micro SD card as well as my 16GB flash drive.
  7. #7
    Quote Originally Posted by nutmeg07 View Post
    Wish I'd looked for this before jumping in... in the same boat as you now though, so how did it go?
  8. #8
    Posts
    ROM
    MiRaGe ROM
    Try BootIt. Can't remember where it's located, but Google search should pull it up pretty easy.
  9. #9
    bjzapp's Avatar
    Where did u hear tht word
    Posts
    ROM
    MiRaGe - IHO CM7.2
    What is the advantage of using the MiniPartition tool program? It is able to format, wipe, re-partition and rename partitions....all of this (maybe without the renaming) can be done using the phone.
    I mean, I installed it on Windows just to check it out but still don't understand using it or the need to.
    Sent via my ZV5 VMOV(ns)
  10. #10
    Posts
    ROM
    MiRaGe ROM
    You can't use the phone/recovery to format the partition to ext.2 or FAT32. FAT32 is used with Froyo ROMs.
    Thank EarthnFire78 for the option in the ZenGarden recovery that formats the partition to ext.4 or back to ext.3.
    Thanks to him there is now no reason to use MiniTool Partition Wizard for Gingerbread, Jellybean, or most ICS ROMs.
  1. Preparing SD Card ... after Wake Up
    By jhmaynard in forum Sprint Galaxy Note 2
    Last Post: 11-23-2012, 10:41 AM
  2. SD card issue using iMac with Droid 2
    By MNTwinsFan in forum Motorola Droid 2
    Last Post: 08-20-2010, 08:26 PM
  3. Any Guide for Setting Up SD Card Folders?
    By indianajonze in forum Verizon Droid Incredible
    Last Post: 05-17-2010, 12:26 PM
  4. "Damaged SD card" after battery swap
    By cm40 in forum Verizon Droid Incredible
    Last Post: 05-09-2010, 10:12 AM
  5. backing up SD card
    By moosc in forum General Help and How To
    Last Post: 04-05-2010, 07:01 PM
