Results 1 to 23 of 23
- 12-10-2012, 08:20 PM
Thread Author #1
LG Optimus V CWM Problem
Hey guys,
I'm new to this forum but I've been looking ALL over it for a solution to this problem and haven't found any so far. So here's what happened.
I had rooted my OV a couple months ago and added a custom ROM and then left it in a drawer because I got a new phone. Recently, I took it out to give it to a friend and by my now realized mistake, I factory reset the device. After this, using CWM 4.0.1.5, I flashed a xionia.zip file onto it. Once flashed, I rebooted the device. And here's where it gets a little... unique versus the other posts I've seen.
The device starts up and shows the LG screen, goes blank for a few seconds, then displays a picture of the Android robot in the background and an arrow coming out of a box as the background. In the foreground, there is text saying:
Android system recovery...
Do not pull out the battery!
Formatting data...
Formatting cache...
After that, CyanogenMod 9 starts up and takes me to the home screen and all seems to be well. However, there are no gapps and all forums tell me to flash the gapps.zip to get them. The problem is, I can't flash anything because every time I boot up, even if I press the buttons to get into recovery mode, it goes straight to that Android system recovery and starts up CM9 instead of showing me ClockworkMod.
What can I do? - 12-11-2012, 06:55 AM #2
Re: LG Optimus V CWM Problem
I would use flash image GUI or a terminal emulator to install a new recovery....start there and see what happens
Downloads are in the thread link below
[HOW-TO] Simplified Root + Recovery + Custom ROM
My HTC Phone - 12-11-2012, 09:46 PM
Thread Author #3
- 12-11-2012, 09:56 PM #4
if you have the terminal app already installed, don't remember if it's already installed on CM9, was on CM7. Go on these forums and download Xionia, Bobz recovery, or CWM and put it on the root of your sd card. Rename whatever recovery you installed as terminal.img. Than flash the recovery using terminal like you would usually do.
- 12-12-2012, 01:44 AM
Thread Author #5
Okay, the problem is partially fixed. I went through the procedure and using the flashing app, I flashed CWM on my Optimus V. After a reboot, CWM finally showed up (yay!).
Then I tried installing a CM7 ROM with gapps. After which I rebooted. However, after the reboot, it goes straight back to CWM. No matter how many times I reboot, it goes back to CWM. - 12-12-2012, 01:50 AM #6
- 12-12-2012, 07:31 AM #7
- 12-12-2012, 06:21 PM
Thread Author #8
I tried two ROMs. First BACKside-IHO-VM670. It booted back into CWM so I tried again and same thing, no luck. Then I tried flashing cm-9.1.0.VM670.BobZhome. Same issue.
How would I go about using a Xionia recovery to do that? Because that's what caused my issue the first time. I had tried flashing a file called Xionia_CWMA_12518.6_VM_Recovery and it managed to get past the CWM and booted up with CM9. But unfortunately, there were no Google Apps and I couldn't get into a recovery. - 12-13-2012, 01:16 PM #9
Xoinia has a bootloop fix....somehow you lost your recovery originally
If it were my phone I would put xonia back on it wipe system, boot, cache, dalvik cache, data
Flash Rom
Fix bootloop
Boot system
Reboot recovery
Wipe dalvik again
Flash gapps
Reboot
My HTC Phone - 12-13-2012, 11:19 PM
Thread Author #10
- 12-14-2012, 05:10 AM #11
[Custom Recovery] Xionia Clockwork (CWMA v1.2518.6)
My HTC Phone - 12-14-2012, 12:26 PM #12
- 12-15-2012, 03:38 PM
Thread Author #13
- 12-15-2012, 05:03 PM #14
- 12-15-2012, 06:28 PM
Thread Author #15
I flashed the zip you PM'd me using CWM after formatting cache, factory reset, dalvik cache, etc. but then after a reboot, I'm getting the same issue I began with.
It shows the Android bot with an arrow coming out of a box and runs the "Android System Recovery" and then gets stuck at the LG splash screen (most likely taking a while to boot up CM9 like last time)... - 12-15-2012, 06:36 PM #16
- 12-16-2012, 02:47 AM
Thread Author #17
- 12-16-2012, 10:52 AM #18
- 12-16-2012, 02:10 PM #19
If your seeing "Android System Recovery" then your looking at the stock recovery. You will have to flash a recovery thru the computer using shell commands after putting the recovery in the platform-tools folder of the Android SDK. I'm on a slow 3G connection. I hope one of the other members can walk you thru the process. If not, let me know
Sent from my LG-VM670 using Android Central Forums - 12-16-2012, 04:18 PM
Thread Author #20
- 12-17-2012, 03:08 AM #21
- 12-17-2012, 10:31 AM #22
- 12-17-2012, 12:09 PM #23
Puppy Slacko or SuperOS 11.10 would be a good start for Linux OS's. SuperOS 11.10 is my daily driver because it has an intella-hide app bar. Puppy Slacko can be used while still on flash drive so it doesn't matter what computer the flash drive is inserted into. You never have to leave your work on your main computer.
Lg optimus s tethering problem
By Pavlovsdog818 in forum LG Optimus S Rooting, ROMs, and HacksReplies: 27Last Post: 03-16-2012, 05:17 PM -
LG Optimus Android Wifi problems
By LakeofGlass in forum LG Optimus S Rooting, ROMs, and HacksReplies: 13Last Post: 03-12-2012, 01:01 AM -
HELP Lg Optimus S rooting problems
By raynier_93 in forum LG Optimus S Rooting, ROMs, and HacksReplies: 14Last Post: 06-10-2011, 10:28 AM -
By raynier_93 in forum IntroductionsReplies: 0Last Post: 06-02-2011, 12:25 AM -
LG Optimus S Contact Problem
By mcbereket in forum LG Optimus SReplies: 3Last Post: 03-05-2011, 01:23 AM
Reply
