02-07-2013 08:47 PM
46 12
tools
  1. Encerspay45's Avatar
    Slow is better than none at all.
    Great work sellers!
    12-25-2012 03:49 PM
  2. flapjack.fiasco's Avatar
    I'm going to take it that he's just trying to help me out by telling me about the build. See my post in his thread, progress will be slow
    Sent from my HTCEVOV4G using Android Central Forums
    That's exactly what I was at. I'd rather see a native build than have to use a patch.
    12-25-2012 04:27 PM
  3. sellers86's Avatar
    Thanks for letting me know, though I'm going to take a different approach to it, might fix most of the issues
    flapjack.fiasco likes this.
    12-25-2012 04:47 PM
  4. bigsupersquid's Avatar
    I've been too distracted to build, but if you want full gapps you could try this:
    build aufs filesystem into kernel (from SourceForge)
    use existing /system/app from your build for base read-only directory
    have init.d script that aufs mounts a 2nd sd-ext partition over /system/app
    copy gapps with adb or terminal after script runs and reboot
    it's possible the os would be uppity on boot from not having access to some apps until the card mounts, but it might work since your base install is accessible.
    nice job getting this to work, by the way!
    12-25-2012 07:37 PM
  5. sellers86's Avatar
    I'm going to get the issues kinked out before anything
    notown likes this.
    12-25-2012 08:03 PM
  6. inceyet's Avatar
    WORD!!! Your a beast sellers great job . Will DEF try out as soon aa I can just to see.
    sellers86 likes this.
    12-28-2012 07:20 AM
  7. sellers86's Avatar
    OP updated with thanks list and a notice on why progress will be slow.
    12-29-2012 11:21 PM
  8. jonny5449's Avatar
    Looks cool hope u can get this up and running
    Sent from my LG-LS670 using Tapatalk 2
    01-10-2013 04:47 AM
  9. MWisBest's Avatar
    Would be nice to see the source code for what you have so far put on GitHub.
    01-17-2013 09:10 PM
  10. sellers86's Avatar
    As soon as i get done with these funerals and get my keys set up.. Why?
    Sent from my PG86100 using Android Central Forums
    01-17-2013 09:21 PM
  11. MWisBest's Avatar
    It'd be a nice project over break to try and get it going on my LG Vortex. I want to see what was done with the androidarmv6 sources to get it built and booted on the Optimus V as the hardware isn't too different between the V and Vortex.
    01-17-2013 09:39 PM
  12. sellers86's Avatar
    IIRC, all changes were in the device tree.
    01-17-2013 11:10 PM
  13. willmon22's Avatar
    Just seen this today. I am going to download it and try it out. Thanks for making a rom of the latest android sellers you are awesome.
    02-06-2013 03:43 PM
  14. willmon22's Avatar
    Thought I would review the rom and give my opinion on it. The rom itself is fine. I will compile a list as writing sentence after sentence takes too long.
    1. Phone/3G Network
    2. Wifi
    3. Bluetooth
    4. Camera
    5. Sound
    6. Vibration
    7. Brightness adjust
    8. Screen Rotation
    9. Sound Recorder
    10. Headphones
    Things that do work
    1. Font size adjust
    2. Changing Wallpaper
    3. Rom boots and fuctions
    4. Lock Screen
    5. Pattern lock screen
    6. Gmail installs
    Also there is the USB storage. When I first installed the rom it worked fine. But now it isn't. I had tried to install the newest gapps and it went through fine with no errors. Just I can't seem to find the google play market just gmail. I am going to be testing the rom further to see if I can find any other issues. Also if I find ways around certain issues I will post them. Other than that sellers I hope this info helps out. I can try to confirm more but I would have to find out how to install apks without there being a filemanager installed already.
    02-06-2013 06:13 PM
  15. thewraith420's Avatar
    Not knocking sellers work on this but you should check out kravens jb work in the Optimus S forums. It has more working since he's had more time working on it.
    Tapatalk'n it from my VM670 running OM-Mandylion on LS670ZVJ firmware
    02-06-2013 11:17 PM
  16. sellers86's Avatar
    I actually recommend thekravens build, as I am no longer working on this.
    Sent from my PG8610000 using Android Central Forums
    02-07-2013 07:48 PM
  17. Ryuk6666's Avatar
    Lol, I don't know why, but I knew you were going to say you recommended the kravens. But I'm kind of surprised that you stopped working on it.
    Sent From My 4.2.1 PrimoC... CodeFireX Style.
    02-07-2013 08:06 PM
  18. Ryuk6666's Avatar
    Lol, I don't know why, but I knew you were going to say you recommended the kravens. But I'm kind of surprised that you stopped working on it. D: although I know you have your reasons
    Tapatalk, why u no work? D:
    02-07-2013 08:07 PM
  19. sellers86's Avatar
    I said in my thread I would no longer be maintaining 4.2 for the optimus v.
    02-07-2013 08:18 PM
  20. upconvert's Avatar
    I thought it was cool that you got it working at all. I hope things are going better for you. I'm glad you're still checking in here.
    Sent from my GT-P7310 using Android Central Forums
    02-07-2013 08:38 PM
  21. sellers86's Avatar
    Actually I really haven't been. I get notifications on my phone when posts are made on my threads. Things are getting better, I hope to be back soon.
    02-07-2013 08:47 PM
46 12
  1. [ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
    By Oathkeeper1212 in forum AT&T LG Phoenix/Thrive
    Last Post: 07-22-2014, 12:53 AM
  2. [ROM] CyanogenMod 10 for optimus T
    By XoMxcted in forum T-Mobile Optimus T
    Last Post: 10-14-2012, 09:33 PM
  3. Cyanogen 6 ROM for the Optimus V
    By dEris in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 07-22-2011, 11:50 AM
  4. CyanogenMod 7 for the DX?
    By ddodge68 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 02-18-2011, 06:00 AM
  5. Is Cyanogenmod out for the Fascinate yet?
    By MolecularGraph in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 12-17-2010, 11:24 PM
