- 01-21-2013, 02:58 PM
Thread Author #1
[HELP!?] Quattrimus constantly rebooting
For along time ive had backside IHO for my op v, but I wanted a changed so I flashed the cm9 quattrimus onto my phone
since then Ive been able to get almost nothing done
anytime I launch an app or make changes my phone reboot
when the rom launches again it says "android updating" or something like that everytime
ive reflashed and even redownloaded the rom and im still getting the same results, are there any fixes for this? would the AOPK version work better?(ive flashed the AOPK version and im still experiencing the same problems)
please helpLast edited by Brandon Musty; 01-21-2013 at 04:56 PM.
- 01-21-2013, 03:26 PM #2
Re: [HELP!?] Quattrimus constantly rebooting
The Android updating is normal since ICS 'Android 4.x' came to be. Its telling you that there was a change in an application and its updating the file system on reboot. This will normally happen if you do a dalvik wipe or system reset, etc. also.
As far as your rebooting problem I'm not too sure why that is happening, I'll let someone more familiar with your device & ROM try to answer that.
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 01-21-2013, 05:16 PM #3
That was every cm9 or 10 I put on my v.....just couldn't handle it I guess....
Some people say tweaking your governor and oclock settings help, but I never had an luck
Post in the thread you downloaded from for more tips
Sent from my PG86100 using Android Central Forums - 01-21-2013, 05:21 PM
Thread Author #4
- 01-21-2013, 06:00 PM #5
- 01-29-2013, 04:24 PM #6
I have been using the same rom and have found that if you keep you min at 600, it does not reboot. anything less that 600 eventurally caused a reboot for me. Right now my settings are: InteractiveX Min 600 Max 806. The only issue I am having now is that CM9 does use more battery, although I can usually make it through the day on one charge.
- 01-29-2013, 05:22 PM #7
It's using more battery for two reasons.
Problem with deep sleep mode and your min is higher than 480MHz.
The min is where the processor idiles. At 600MHz it doesn't catch a break.
Remember: The stock ROMs max is 600MHz.
Need help phone keeps rebooting....
By kofifi in forum Incredible Rooting, ROMs, and HacksReplies: 6Last Post: 02-01-2011, 01:09 AM -
Evo replacement for constant reboot issue
By darkborne in forum HTC EVO 4GReplies: 5Last Post: 12-20-2010, 10:04 AM -
Every new cyanogen build results in a constant reboot
By shaker3818 in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 5Last Post: 09-13-2010, 12:48 PM -
Constant rebooting. Why?
By FreezingD in forum Verizon Droid IncredibleReplies: 36Last Post: 06-09-2010, 12:41 PM -
Constant rebooting when trying to flash ROM
By wolf1989#AC in forum HTC Hero Rooting, ROMs, and HacksReplies: 10Last Post: 04-17-2010, 05:01 PM
Reply
