Results 1 to 4 of 4
    Default Wrong recovery on Optimus V. Need Help!!
    Hello this is my first post in the forum. im not really a noob when it comes to rooting, flashing, etc. but i cant seem to figure this one out. i accidentally flashed cwm recovery 5.0.2.7 on my optimus v from Rom manager (i know big mistake). but since this recovery isnt made for the v i cant select anything in recovery mode to flash a new recovery or rom and trying to boot the phone normally results in a boot loop. ive tried using adb to flash a new recovery to no avail. Someone please help me fix this phone so i can actually use it as something other than a coaster.
  2. #2
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Default Re: Wrong recovery on Optimus V. Need Help!!
    Can you boot to your rom still?
    Sent from my VM670 using Tapatalk 2
  3. #3
    bjzapp's Avatar
    Where did u hear tht word
    Posts
    ROM
    MiRaGe - IHO CM7.2
    From what he has stated, NO...in a boot-loop
    Have you gone through the stickies?
    I know this problem and a fix has been posted numerous times...
    Good luck
    Sent via my ZV5 VMOV(ns)
  4. #4
    AndyOpie150's Avatar
    Posts
    ROM
    MiRaGe ROM
    Dskills8:
    go to the Rooting, ROMs, and Hacks sub -forum.
    Scroll down till you see the the ZenGarden recovery.
    Download the zipped version and put onto the root of the SD card. Leave it zipped.
    Make sure you have a ROM zip (and Gapps if needed) on the SD card as well, as the current ROM probably got borked too.
    From the recovery:
    Flash the recovery zip.
    Then go to the advanced section and choose to reboot recovery.
    It will boot into the ZenGarden recovery.
    I can't remember exactly where in the menu, but it has a fix recovery loop option. Select it then go to the wipe options and select eveything once.
    Flash ROM (and Gapps if needed). Rebbot.
  1. Optimus V stuck in Recovery Loop, wiped SDcard, Need help on mac
    By jacob.bowers in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 01-09-2012, 11:55 AM
  2. Semi-Bricked Optimus V Need Help
    By Juteboxzero in forum General Help and How To
    Last Post: 09-25-2011, 02:17 AM
  3. LG Optimus V need help with running games PLEASE!
    By coldcrush390 in forum Virgin Mobile Optimus V
    Last Post: 04-05-2011, 06:11 AM
  4. Rooting with Better Terminal Emulator on Droid X, need help
    By BrownHornet72 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 09-15-2010, 11:29 PM
  5. On the Fence .. Need Help Plz
    By VKitty in forum HTC EVO 4G
    Last Post: 07-07-2010, 10:32 AM
