Results 1 to 12 of 12
    QuinnSF's Avatar
    Posts
    Global Posts
    123 Global Posts
    Default HELP My phone won't boot up!!!
    My SD got ejected so I thought I'd reboot my phone instead of taking it out and putting it back in. Now my phone won't turn on. I am running MiRaGe and my phone won't go past the green android icon with the word "ANDROID" on the bottom. It'll show the LG icon and then the green android mascot icon but after that there's nothing but a black screen and lighted up buttons. I've tried booting with my phone plugged in and that does the same thing. If I pulled my battery and then put it back while plugged in, I'll get the charging icon. If I have it plugged in but no battery, it'll tell me to insert a battery. What do I do??? I've tried booting into recovery by pressing all the button at once and bu pressing the power button, home button, and down button but I have not been able to get anything so far.
  2. #2
    AndyOpie150's Avatar
    Posts
    Carrier
    Bean_Whiz-CM10v2.2.2CX
    Default Re: HELP My phone won't boot up!!!
    Have you tried getting into your recovery by unplugging phone from any power, then pressing the keys in this order exactly:
    HOME + VOLUME DOWN, then push the POWER. Hold everything until you see the LG logo, then let go of all buttons.
    If this doesn't work we wil need to see if you can get into Emergency mode.
    BACK + VOLUME DOWN, then plug into computer.
    Let me know how it goes.
    QuinnSF's Avatar
    Posts
    Global Posts
    123 Global Posts
    Quote Originally Posted by AndyOpie150 View Post
    I got into recovery mode and from there I rebooted my phone and it booted up as normal. Thank you!
  4. #4
    I am having the same problem. I have HTC One M8. My apps started crashing one after another. I could not open a single app. So I tried the factory reset option. But now the phone doesnt turn on. the screen gets stuck in the boot page with htc and beats audio. can you help me out as well? the whole problem started since I updated the Kitkat 4.4. pleaseeee helpp
  5. #5
    badblue1__'s Avatar
    Posts
    Carrier
    MiRaGe *PurePerformance*
    This is the LG Optimus V forum, you will do better posting in the HTC One M 8 forum .
  6. #6
    i rooted my phone and i happened to accidentally uninstall an app and my phone wont open.. only the welcome screen appears and it stops there Please help me too. Is there a way to open my phone? Please help me Please!
  7. #7
    bigsupersquid's Avatar
    o_O
    Posts
    Carrier
    bigsuperROM_os2sd
    Quote Originally Posted by Hazel Green1 View Post
    if you're rooted, did you install a custom recovery? if so, the instructions should've told you to make a backup. you can restore that and be ok.
    if you didn't install a custom recovery you can factory reset in the stock recovery (probably lose root but you can get it back.)
    you are using an optimus v phone, correct?
  8. #8
    Please help me my phone wont boot either, it wont pass the Blu luanch screen...i have a Blu advance 4.0 android 4.2.2 jelybean.
  9. #9
    I rooted my phone and it wont boot up i tried doing factory reset that did not work i am on samsung s5
  10. #10
    my mobile colours teletalk X120Q is not starting. after press volume down + power it gives option of boot but on boot the phone is not starting up it only shows logo
  11. #11
  12. #12
    o_O
    Posts
    Carrier
    bigsuperROM_os2sd
    Quote Originally Posted by Jeffrey Sim View Post
    Quote Originally Posted by Romey101 View Post
    Quote Originally Posted by sonu kumar12 View Post
    sorry folks, optimus v forum, can't help with any of those devices here.
  1. Help! Screen blacks out on speaker
    By Beheima in forum Moto X (2013)
    Last Post: 11-05-2013, 05:58 PM
  2. What Android world-phone do you recommend me??
    By Dx3me in forum General News & Discussion
    Last Post: 11-04-2013, 11:57 PM
  3. Replies: 1
    Last Post: 11-04-2013, 10:55 PM
  4. Replies: 8
    Last Post: 11-04-2013, 03:25 PM
  5. Issue using earphones on new phone
    By mjdelaney80 in forum Samsung Galaxy S4
    Last Post: 11-04-2013, 02:07 PM
