1. jamoosh's Avatar
    Hi everybody,
    I've been having some issues, which I've seen documented in the Mirage ROM thread and elsewhere, but haven't been able to find the solution to my issue.
    I have Mirage ROM on my Optimus V and installed Link2SD around the same time that was set up. I believe everything to be set up appropriately in Link2SD and with the SD card partitioning, however my system cache at /cache/download keeps filling up, causing me to be unable to install Play Store applications.
    I can delete the folder contents or wipe cache through the recovery menu, however after the next reboot it will have filled back up to the point of unusability.
    There is probably some simple thing that I neglected to do, but if anybody could guide me in the right direction, that would be super.
    Thanks!
Name:	2014-03-30 18.28.37.png
Name:	2014-03-30 18.28.49.png
    03-30-2014 06:43 PM
  2. AndyOpie150's Avatar
    Please read this: http://androidforums.com/showthread.php?p=5605457
    Then wipe and format everything in your recovery but the main FAT32
    SD card (Format the ext.4 partition on the sd card for sure though).
    Then check the md5 sum of the ROM and Gapps before flashing.
    jamoosh likes this.
    03-31-2014 04:27 PM
  3. jamoosh's Avatar
    Thanks for your response, AndyOpie150.
    These are the steps I followed when I first flashed the ROM on the system and set up Link2SD. I don't recall if the directions were followed to the T as I feel like I recall encountering some partitioning issue. Regardless, I hadn't had this problem for the first six months of running the ROM. It only began recently.
    So then I should just go into recovery and format the Ext4 partition (the first partition) and that would likely resolve the issue?
    Thanks again.
    04-04-2014 04:48 PM
  4. AndyOpie150's Avatar
    I think your going to have to check the md5 sum of the downloaded ROM and Gapps first. Install either the Touchscreen ClockworkMod recovery or the BobZohme (VM670_NH recovery). Then, as you go thru each wipe option, go to the mounts and storage section and make sure the cache partition is not mounted (can't wipe a mounted partition). Then when done with all the wipes (including the dalvik cache), go back to the mounts and storage and format everything but the actual FAT32 SD card partition.
    If you do all this before you flash the ROM and Gapps you should be all right.
    What did you use to make the partition? The recovery, or Mini Tool.
    What size is the partition? 1GB or two.
    What size is your SD card? You can only have a partition that is no more than 20% of the actual space available. This means you need an 8GB or larger SD card to use Link2SD properly.
    I have a 1GB partiton with 80-90 user apps installed. No problems what so ever.
    Also: You could have some corruption on the SD card, so first, put the SD card into computer. Transfer data to computer. Format the FAT32 partition by going to Start/Computer/right click on then SD card icon/select format.
    Transfer data back. Re-insert into phone. Go to the recovery menu and do all of the aforementioned wipe and formats before flashing the ROM and Gapps.
    jamoosh likes this.
    04-04-2014 07:25 PM
  5. jamoosh's Avatar
    Thanks for all of the information. It still seems odd to me that this issue would occur suddenly--it seems that there is some misfit application that must be filling up the cache folder with data.
    In any case, it sounds like I will probably have to start from scratch as outlined--I just won't have the time to invest in that for a little while.
    I created the partitions in Recovery. I have the touch recovery installed at this time.
    1 GB. Total: 0.98GB | Used: 217MB | Free: 791MB
    8GB
    Thanks again for all of your help.
    04-16-2014 04:18 PM
  6. yaconsult's Avatar
    Have you tried plugging the phone into your computer and using adb shell to examine the contents of /cache? You can see which files are using lots of space. And after cleaning cache, you should be able to tell which applications are filling it up.
    Is cache the size you expect it to be? For comparison, here is what mine looks like:
    # df -kh
    Filesystem Size Used Available Use% Mounted on
    tmpfs 212.8M 44.0K 212.7M 0% /dev
    tmpfs 212.8M 0 212.8M 0% /mnt/asec
    tmpfs 212.8M 0 212.8M 0% /mnt/obb
    /dev/block/mtdblock5 164.5M 117.4M 47.1M 71% /system
    /dev/block/mtdblock6 178.9M 146.4M 32.5M 82% /data
    /dev/block/mtdblock1 110.1M 53.1M 57.0M 48% /cache
    /dev/block/vold/179:2 1.3G 578.0M 720.9M 44% /data/sdext2
    /dev/block/mtdblock1 110.1M 53.1M 57.0M 48% /data/dalvik-cache
    /dev/block/vold/179:1 13.4G 3.7G 9.7G 27% /mnt/sdcard
    /dev/block/vold/179:1 13.4G 3.7G 9.7G 27% /mnt/secure/asec
    /dev/block/dm-0 3.1M 1.0M 2.0M 34% /mnt/asec/com.pannous.voice.actions.free-1
    Use du to figure out where all the space is going - dalvik-cache or download:
    # du -ck /cache/* | sort -nr
    52877 total
    50546 /cache/dalvik-cache
    2328 /cache/download
    2 /cache/recovery
    2 /cache/lost+found
    Assuming it's dalvik-cache, check out how much space is being used by which apps (biggest ones are at the top):
    # du -ck /cache/dalvik-cache/* | sort -nr
    50544 total
    8029 /cache/dalvik-cache/system@framework@framework.jar@classes.dex
    5025 /cache/dalvik-cache/system@app@Talk.apk@classes.dex
    4687 /cache/dalvik-cache/system@framework@core.jar@classes.dex
    3922 /cache/dalvik-cache/system@app@Vending.apk@classes.dex
    3319 /cache/dalvik-cache/data@app@com.cootek.smartdialer-2.apk@classes.dex
    1938 /cache/dalvik-cache/data@app@com.bestappsmarket.android.bestapps-2.apk@classes.dex
    Good luck, and let us know what you find.
    04-18-2014 11:33 AM
  7. jamoosh's Avatar
    Thanks so much for this information. I'll connect up through ADB and check things out.
    I presume that I will learn more by connecting through android debugging than I would by simply browsing the directory through a root-enabled file manager.
    (...content truncated)
    04-23-2014 12:11 PM
  1. Cached data question
    By beeare in forum Motorola Droid MAXX
    Last Post: 03-31-2014, 05:06 PM
  2. Help to fix no media and system sound..
    By hojadraot in forum General Help and How To
    Last Post: 03-30-2014, 09:40 AM
  3. Reinstalling android system from 4.1.1 to 4.1.2
    By h3060 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-30-2014, 02:27 AM
  4. 4.4 - contacts not showing in car audio system
    By nalab1 in forum Android 4.4 KitKat
    Last Post: 03-26-2014, 12:10 PM
