Help! ADB problems in TWRP recovery (no OS or SD card) Phone keeps showing up as "MTP USB Device"...
So, long story short, I flashed the OS2SD kitkat rom floating around. Its amazing!
There's all this free space when everything is on the SD card!
Until my SD card crapped out on me. Ugh.
Right now, I have a phone with a functional TWRP OS2SD recovery, but nothing else. SD card is totally borked.
My last shot is ADB, or I'll just be without a phone for a week until I can get another SD card. ie, not an option!
ADB Sideload doesn't work without an SD card. >.>
I've spent the last 2 hours trying to get ADB installed. It *looks* like it should work- Android-sdk-windows has all the right files.
I updated my Java software.
I go to Device Manager, and the "phone" shows up as MTP USB Device
There is also an option at the top of device manager for 'ADB Interface -> Android Sooner Single ADB Interface'
Unfortunately, I seem to be stuck, since the phone isn't being listed properly in device manager.
I have the distinct feeling that the phone isn't in USB debugging mode, but in this recovery I don't see an option.
If anyone can help me, anything and everything is greatly appreciated.
EDIT-
When I leave recovery and let the phone attempt to boot (black screen), an option on Device Manager appears, under 'other devices' called simply 'Android'. Unfortunately other than getting my hopes up, it doesn't seem to serve any purpose.
EDIT-
