ARCHIVED: [ROM][WIP][ALPHA] aospCMod | AOSP 2.3.4/CM7 (GB)
Status
Not open for further replies.
dburg
92
58
gapps-gb-20110325-signed.zip
MD5: 4cbe712c0bde778fb7f2d32d32b57dd8
aospCMod-OV-20110531-signed.zip available on Rom Manager under "Download Rom"
aospCWMod-OV-20110531.img
MD5: e75e92d259c675b9dfd5113bd1cd0939
WIKI
Follow AOSPBOT on Twitter for latest OV updates
Live Support
[GPL] Kernel Source
Original XDA Thread
aospCMod from Optimus V to Optimus S .zips
HOWTO Logcat (DEBUG)
PC via ADB:
adb logcat > /path/logcat.txt
ctrl+c
Phone via Terminal emulator:
logcat > /sdcard/logcat.txt
press the trackball (for ctrl) and c to end the output.​
ROM/Kernel DEV: aosp (Donate)
I'm just sharing the rom link with android central.
nice!
An what are the differences between this and Zephie's work with Xionia and CM7?
I think he's using zephie's kernel as its linked in his OP. Buttons are right. Says Virgin, etc etc. Still sync'd with CM source so it should be pretty close. There is a wiki here if you want to test the rom please update it with me.
aospCmod wiki
The ClockworkMod Recovery 3.0.0.6 is nice. If you're unfamiliar with it, it requires Edify only scripting. So all older scripting (Amend) will not work.
Does WiFi tethering work with this?
I am running RevolutionRed's ROM + Kernel package and WiFi tethering doesn't work with it.
Would love to try this out if it can get me that functionality again.
Thanks
Thanks
Can't test until I get home from work. aospCmod for heroc tethering works with the app. Notnative.
testing now, but seems to freeze up on the cyanogen boot screen. Wiped cache and davalik cache. Noob here so it might be my fault.
I haven't flashed it yet, but did you update the recovery to Clockwork Mod? The Repo says you need CWM 3.0.0.x to get it to flash correctly so if you're using thunderc, you may need to change.
I'm personally waiting for further confirming this works well.
Yeah i used all files included in the post he linked to at xda.
edit: forgot to factory reset it/wipe things under the mounts and storage format option.
Booted fine now. My bad, beginner mistake.
will report in later on how the build is.
How to change to the CWM recovery from thunderc?
Reactions: keystonep1mz
I'm having an issue with the headset quality when I'm listening to music and what not...anyone else experiencing this? Does anyone know if there is an easy fix? Thanks a lot.
Update - I have this issue with all the Gingerbread ROMs out there...
flashed to CWM and flashed rom easily, phone seems to be overheating now while phones on.
When I receive texts it comes as "From 99999999" and msg is in chinese
Trouble Flashing CWM
I used these commands and get an error saying "No more space".
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
cat /sdcard/flash_image > /system/bin/flash_image
chmod 755 /system/bin/flash_image
mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
flash_image recovery /sdcard/recovery-clockwork-3.0.0.6-ov-20110220.img
reboot recovery
When it reboots to recovery, there is a Blue Fastboot screen and no recovery. Anyone else have a better method of getting CWM going. Im coming from RA-thunderc.
su
reboot recovery
Flash the ClockworkMod Recovery - ROMRepo
I used method 3. Worked first try. only other issue I'm having is Car Home closes instantly when I open it.
Reactions: Godbilla and cnega
Car Mode doesn't work for me either (same issue - goes back to home screen). Otherwise, pretty cool to have 2.3!
I'm debating whether I am going to overclock with SetCPU. Phone does feel a bit warm so maybe I will use SetCPU to throttle down the CPU at idle.
Thanks!
Status
kuzmaj05
