Cyanogen 6 ROM for the Optimus V
Eollie
1,534
258
I see your Clicky and raise you Clicky yourself.
ruamilf
MMS working
i just flashed the aospCMOD build 20110601 last nite, and recieving mms works, havent tried sending yet.
the battery drain's much faster and the phone is a LOT warmer then again i am running at 846 mhz instead of 600 mhz im going to try at 600 and see if there is a diff. i see what you guys are saying about a nice CM6 the only reason i like cm7 better is the wifi/BT/GPS/sound widget on the pull down notification bar, dont have to scroll through home screens to find the "power control widget"
r00t
171
13
You can achieve widgets with an app. BTW, if you haven't noticed this is a CM6 discussion.
roxasj9112
6
Yeah, I've been trying to find a CM6 for my Optimus V.. no such luck :(
___________
LG Optimus V
Ath3ros 2,3,4 CM7
Xiona 013 Kernel
CWM 3.2
Working MMS Babayyyyyy :D
Kreatur3
660
40
___________
LG Optimus V
Ath3ros 2,3,4 CM7
Xiona 013 Kernel
CWM 3.2
This...thread...is...dead.
Never was developed, stick with CM7 as CM6 isn't going to happen for the OV.
Thanks
Sleezzyy21
