Page 1 of 4 1234 LastLast
Results 1 to 25 of 97
    cpshelley2's Avatar
    Posts
    Carrier
    Aphrodite 1.3.3 Xionia 05
    Default "Time without signal 50%", airplane mode fix, and possible build.prop solution?
    i was digging around in my build.prop file and found the following line:
    ro.telephony.default_network=4
    does anyone know what this setting does, or does anyone know if changing this value might fix the time without a signal bug? i was thinking that maybe this setting has something to do with the default network setting being incorrect... sorry if i'm not being clear here, i can't find the original post where i first saw this...
  2. #2
    whyaphoenix's Avatar
    Posts
    Carrier
    AOSPCmod 7 2.3.3
    Default
    delete
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    would you mind posting your build.prop file please?
  4. #4
    Liquidplacidity's Avatar
    Posts
    Carrier
    aospmod recent
    Default
    Quote Originally Posted by cpshelley2 View Post
    I just looked in my build prop file, and im running Aosp 04/15. The time without a signal bug is fixed but the prop says the same thing as yours. Default network is 4. I'm wondering how they fixed it.
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    yes, i downloaded aosp and checked the file, i noticed it was the same... maybe this bug was somehow fixed in 2.3? my current ROM is Aphrodite, so it's running 2.2.1...
  6. #6
    LeslieAnn's Avatar
    AC Forums Android Developer
    Posts
    Carrier
    Harmonia 3
    Default
    The problem isn't going to be so easy to fix.
    My guess is that it is most likely in:
    system/lib/modules/wireless.ko
    system/bin/wl
    system/bin/wpa_supplicant
    And you won't be editing those very easily.
    Most other files related to this are either identical, or easy to see they are relatively meaningless.
  7. #7
    Posts
    Carrier
    aospmod recent
    Default
    Nope, it wasn't 2.3 that fixed it. I noticed that it was fixed after the April third release of Aosp. But any previous aosp rom before that and it'd still do it.
  8. Thread Author  Thread Author    #8
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    Quote Originally Posted by Liquidplacidity View Post
    very interesting... i'm curious as to what changed in that build...
  9. #9
    drezliok's Avatar
    Posts
    Carrier
    I.H.O. Mirage CM7.2
    Default
    This fix information needs to be documented and or linked to said documentation for all the Devs and users alike.
    It would be nice to now have to use the work around procedure or the does it for you app.
  10. Thread Author  Thread Author    #10
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    Quote Originally Posted by drezliok View Post
    i don't mind the airplane mode fix, but sometimes i forget, and it would be nice, as you said, to have this documented so i can just turn on my phone and go.
  11. #11
    Posts
    Carrier
    AOSPCmod 7 2.3.3
    Default
    delete
  12. #12
    Default
    There was a flashable fix floating around a while ago that would automatically do the airplane mode thing at boot for you so you wouldn't have to. Worked like a charm, you just flash it and forget about it. No more 50% cell standby issue. I just don't remember where i found it.
  13. Thread Author  Thread Author    #13
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    i believe this may be what you're talking about:
    [APP] 50% time without a signal fix - 2/2/2011 - xda-developers
    thanks for the heads-up on that, prime, it works great!!
  14. #14
    phreak311's Avatar
    Posts
    Carrier
    Stock Root, Phone and Tab
    Default
    So yeah this is getting frustrating. My girlfriend has the Optimus V, and I have the Optimus S. And I'm no nEwB to android phones. This is the 3rd one I've had. I get 14-17 hours a day under moderate to heavy usage with my Optimus S. I'm running Zefie's CM7 most current build on my Optimus S and I don't have this TWS problem. Never have, since I got my optimus with my Upgrade back in December. But my girlfriend's Optimus V OMFG! It will last probably 6-8 hours on one charge! It's so Effing frustrating. Because I have read through all these forums, and applied the TWS patch, and you can literally sit and watch her battery percentage drop with the phone in your hand. So what is the deal? She loved my phone, so went out and bought the Optimus V and is very disappointed with it, and frankly so am I. I am an android only kind of person. I've had iphone and Blackberry and I <3 Android. BUT WTF IS THE DEAL WITH THE V? I've also tried using all of the different available ROMs for the V, and still horrible horrible battery life. I used to have AOSP installed on her phone as well, and it still got horrible battery life. So what are we to do? Do you think it's possible the phone is defective?
    Do you think it may be that I flashed a different PRL file to the phone and it's searching for a signal more? WHAT IS IT???? WHY??? AHHHHHHHHHHH!!!!
    Thank you lol
  15. #15
    phreak311's Avatar
    Posts
    Carrier
    Default
    Oh yeah, and applying the TWS fix, does not work on her phone, she's still getting reports of around 50% TWS, and her battery life is just awful. The samsung Intercept is horrible, I know because My sister has it on Sprint, but i'm pretty sure she would have been better off getting it...
  16. Thread Author  Thread Author    #16
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    i'm not sure if anyone really knows what's causing this bug... i sure don't. but it seems like with some ROMs, it's there, and some ROMs, it's not. but i had that problem with the stock VM ROM as soon as i got this phone... when you applied the patch, it didn't work? try manually putting it into airplane mode and bringing it back out after 30 seconds? you might very well have a defective phone, or a defective battery... hard to tell.
  17. #17
    phreak311's Avatar
    Posts
    Carrier
    Default
    Yeah, it's just frustrating. I've manually put her phone into airplane mode too, and the TWS isn't that high, about 13%, but her battery is just dying so quickly. I took my S, and her V off the charger this morning at the same time. My phone is on 78% and i'm streaming music from Audiogalaxy right now,and her phone battery is on 49% and she's barely touched it all day...It's just annoying But i'm sure you know that by now lol
  18. Thread Author  Thread Author    #18
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    Quote Originally Posted by phreak311 View Post
    yeah i feel for ya... very frustrating indeed. i don't know what i'd do if the airplane mode trick didn't work... this issue is just so random, it even seems like identical phones with identical ROMs experience this issue differently... GAH!!
  19. #19
    phreak311's Avatar
    Posts
    Carrier
    Default
    Well I called Virgin Mobile, last thing I could think of. I'm having them send me a replacement. So when i get it, i'll root it, and install a Custom ROM and report back my findings as to whether it was the phone, or the bug that I COULD NOT get fixed lol. It should be here in 3-5 business days, so I'll keep you guys posted...
  20. Thread Author  Thread Author    #20
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    sounds good, and best of luck!!
  21. #21
    phreak311's Avatar
    Posts
    Carrier
    Default
    Thank You, and please don't get up on Android phones. Out of all smartphones, iOS, Blackberry, Palm, Symbian etc, I love Android the best. Android may have some small bugs, but you really can't beat it, I mean it's open source...And the features can't be beat...strictly my opinion...
  22. Thread Author  Thread Author    #22
    cpshelley2's Avatar
    Posts
    Carrier
    Default
    i agree with you completely ^_^
  23. #23
    Posts
    Carrier
    aospmod recent
    Default
    What's causing the bug? That's easy. The phones are set to CDMA/GSM auto by default when rebooted. The phone doesn't have a GSM antenna, but it "scans" for GSM towers anyway, so it thinks it can't find a signal, because the antenna doesn't even exist.
  24. #24
    Default
    I don't think that is true. My phone is set to CDMA auto, and it stays the same setting between reboots. I still get the TWS bug without toggling airplane mode.
  25. #25
    Posts
    Carrier
    aospmod recent
    Default
    Quote Originally Posted by mmarz View Post
    Yeah, that's true. It's a visual glitch. I've learned this from all over the internet. I posted a solution somewhere in a random thread, but here it is again. *#*#4636#*#* Phone information. change it to CDMA only. Then back to CDMA auto. Exit out of there and use airplane mode like normally. It'll fix the glitch, and have your phone working right until you reboot it.
    Edit: And no matter how many times you reboot it, it will always say CDMA auto, but it will really be set to CDMA/GSM.
