This is a very fast and easy method to flash a recovery from inside your phone. Probably one of the fastest easiest methods out there.
Note that you need to be rooted first.
Preparation:
You need to put the recovery onto the root of your Sdcard.
Optional but highly recommended, rename the recovery "a.img", minus the quotes of course. This is easier to do on your computer and means a less typing on the phone. If you don't rename it, you will have to type out the entire name in step 2. The same applies if you have it in a sub-directory.
1. Open your emulator
2. type in, pressing enter after each line:
su
flash_image recovery /sdcard/a.img
3. If you want to boot straight into recovery, type:
reboot recovery
Preparation:
su
reboot recovery
