1. msciresa's Avatar
    I am stuck in recovery mode! I can flash vmfastboot but the phone just goes to recovey, i can change recovery from android explorer but it just stays in recovery, please help!
    06-30-2011 09:04 PM
  2. logankokskin's Avatar
    Same problem, PLEASE HELP!!!!!!
    07-12-2011 11:32 PM
  3. mmarz's Avatar
    Flash this with your recovery:
    Xionia_CWMA_12518.4_VM_Recovery.zip
    07-13-2011 01:16 AM
  4. jchaley50's Avatar
    dude mine is stuck idk how this will help
    01-12-2012 09:45 PM
  5. Badboytoast's Avatar
    Flash the .zip and do a normal rom install I would use hormonia 2.03, why you may ask? Because all you need is the rom, reboot and enjoy " when I say install rom normal" I mean wipe data/factory , wipe chach,wipe delivic, format, boot,chach,date,system, wipe date/factory again install rom reboot and wait. Hope this helps
    Cwm base recovery 4.0.1.5
    Hormonia 2.03
    01-12-2012 10:04 PM
  6. Badboytoast's Avatar
    What do u mean by "I can change recovery from android explorer "???
    01-12-2012 10:07 PM
  7. CuriousNoob's Avatar
    That was posted July1, no reply most likely... Id suppose its when you click 'Install rom from sd'
    01-12-2012 10:13 PM
  8. Badboytoast's Avatar
    Lol thanks it happen again I keep on forgetting to check the date lol
    01-12-2012 10:19 PM
  9. Sonny Ng's Avatar
    hi buddy, the link is down, would you mind to share it again?
    thanks for your time.
    12-24-2012 09:53 AM
  10. bigsupersquid's Avatar
    here's a xionia 125186 recovery flashable zip
    http://forums.androidcentral.com/att...ery-signed.zip
    you can also use drew's cot recovery from the optimus s forum, or earth n fire's zengarden recovery
    http://forums.androidcentral.com/opt...21-2012-a.html
    12-24-2012 11:38 AM
  11. thewraith420's Avatar
    Cot isn't available in the s forums anymore but here's a link to get the VM670 version
    Edit: forgot the link
    http://forums.projectopencannibal.ne...php?topic=42.0
    12-24-2012 12:44 PM
  12. Sonny Ng's Avatar
    Thanks a lot
    12-24-2012 02:04 PM
  13. Michael Okoh1's Avatar
    just look around your tablet (china made) you will see a small hole, use a pin to click the button in the hole.
    08-31-2013 05:32 PM
