Results 1 to 12 of 12
- 06-30-2011, 09:04 PM
Thread Author #1
- 07-12-2011, 11:32 PM #2
- 07-13-2011, 01:16 AM #3If You Enjoy My Work, Consider Donating.
Thank You! - 01-12-2012, 09:45 PM #4
- 01-12-2012, 10:04 PM #5
Re: help! i can't get out of recovery mode
Flash the .zip and do a normal rom install I would use hormonia 2.03, why you may ask? Because all you need is the rom, reboot and enjoy " when I say install rom normal" I mean wipe data/factory , wipe chach,wipe delivic, format, boot,chach,date,system, wipe date/factory again install rom reboot and wait. Hope this helps
Cwm base recovery 4.0.1.5
Hormonia 2.03 - 01-12-2012, 10:07 PM #6
- 01-12-2012, 10:13 PM #7
That was posted July1, no reply most likely... Id suppose its when you click 'Install rom from sd'
Sent from my LG-VM670 using Tapatalk - 01-12-2012, 10:19 PM #8
- 12-24-2012, 09:53 AM #9
- 12-24-2012, 11:38 AM #10
here's a xionia 125186 recovery flashable zip
http://forums.androidcentral.com/att...ery-signed.zip
you can also use drew's cot recovery from the optimus s forum, or earth n fire's zengarden recovery
http://forums.androidcentral.com/opt...21-2012-a.html....**.../\…•^•…/\...**....
|..................................| - 12-24-2012, 12:44 PM #11
- 12-24-2012, 02:04 PM #12
Reply
it happen again I keep on forgetting to check the date lol
