Results 1 to 6 of 6
- 07-02-2011, 10:06 AM
Thread Author #1
- 07-02-2011, 03:11 PM #2
Re: Help! Optimus V Stuck In Recovery Loop Bricked!
Unfortunately, you are going to have to use adb...I got out of the loop on my friend''s V by using mmarz's guide listed below. I would reccommend trying this first because it was simpler. http://forum.androidcentral.com/opti...ory-reset.html
Also, here is a guide to adb commands
I see this is also posted over at XDA, I believe mmarz is trying to help; let us know how you're doing - 10-24-2011, 10:00 AM #3
Listen guys, i have the optimus c with cricket. i am having the bootloader issue after using rom manager to manually go to adb, this did not work it rebooted my phone and now i am permanently stuck on the LG splash screen, completely bricked, no button combination will work to factory reset or to get into emergency mode, nor any method to reload the .rom onto the sd card (unable to connect and read my phone through cpu). i reinstalled drivers and nothing, also tried mmarz method, asadullah's fastbootroot, and kdz. since i am unable to connect phone and extract anything to sd card, i am completely lost. is there any other methods that you may know of or is there anyone that has experienced this issue??????? please let me know
- 12-18-2011, 04:05 PM #4
First off, I am a newb. My phone is stuck in a recovery loop and I've been reading on this for 2 days now with no success.
History: I rooted my LG Optimus V running 2.2.2 with gingerbreak a couple of months ago, mainly (at that time) so that I could perform serious backups on my phone and never be in a position to have lost anything. Per all instructions I could find, I installed SuperUser, Rom Manager, Titanium Backup, I also have another backup by Rerware, but I can't remember the name of it.
So, being the data-hoarder that I am and the fact that I need more room for more apps
, my husband bought me a 32 gig micro card for Christmas. So, as per instructions found elsewhere, I made a backup to my sd card, (several in fact on each backup software), copied my sd card to my hard drive, partitioned my new sd card, and loaded the new sd card with the old sd card data. At that point everything looked fine. But the instructions said to restore from my backup which I did with clockworkmod and now I am stuck in a recovery loop. I did not do an android system restore, which seems to be most people's problems with boot/recovery looping.
I completed Kionia CWMA install 1..4 and performed "Fix Recovery Boot Loop" but it did not fix the issue.
I completed Kionia CWMA install 1..6 and performed "Fix Recovery Boot Loop" but it did not fix the issue.
I completed the abd shell instructions "strings/dev/mtd/mtd8" and "flash_eraseall /dev/mtd/mtd8" but it did not fix the issue.
I do not know what to do next...please remember that I am a newb...I don't want to be an android programmer (I was a windows programmer in a LONG AGO previous life and do not wish to return...) but I will do anything to get my phone back at least functioning. I was careful when I was installing the new sd card and am now SOOOOO disappointed that I thought I was covered with the backups I had, only to find out that the backup program does not even work properly...
Thanks to whoever is out there for any help... - 07-03-2012, 03:41 PM #5
- 07-03-2012, 06:25 PM #6
we'll first off sounds like most of you used the dreaded rom manager which is a HUGH NO NO that will brick your phone its not intended for the ov (trust me I found out the hard way
) but sounds like adb is probably the only fix when your fixed get your self a nice iho rom like harmonia 2.08, MiRaGe, or backside just don't start out with a ics just yet get your feet wet first.good luck
Sent from my LG-VM670 using Android Central ForumsLast edited by inceyet; 07-03-2012 at 06:30 PM.
But as long as you can both get to recovery and access the phone via adb, you'll be okay.
Reply
