Results 1 to 4 of 4
    Default Sideload Wonder Machine Help
    Reading through the forums I've noticed a few people having the same problems I am with the Sideload Wonder Machine. Every time I try to install an app on my X10a it gives me a 'device not found' error.
    Post here if you are having similar problems or know how to fix this.
    Thanks.
  2. #2
    brett1's Avatar
    Posts
    Global Posts
    8 Global Posts
    Default Re: Sideload Wonder Machine Help
    tried alsorts on my x10 mini pro, no joy downloaded to pc to but nothing to to phone
  3. #3
    luckystreak's Avatar
    Posts
    ROM
    MiniCM7 Pro v7x
    Quote Originally Posted by Ramslayer View Post
    Thanks.
    Hi, i'm no expert but you need to install SE USB drivers. Go to Android SDK site and look down left hand side and click on OEM usb drivers. That will point you in the right direction for the correct driver for your phone. Instructions to install can be found on the Google usb driver.r4 link. Hope this helps.
  4. #4
    Default
    I used the SWM when i first got my x10, I had to put it in the root directory on my hard drive to get it to work properly.
    Sent from my X10i using Tapatalk
