Results 1 to 5 of 5
    Default Question - uninstall/delete Bruce Lee and The Sims 3?
    Hi, I am new to the android (old blackberry user) and I got a quick question. Is there a way to uninstall/delete Bruce Lee and The Sims 3 from the phone?
  2. #2
    honex97's Avatar
    Posts
    Global Posts
    237 Global Posts
    Default Re: Question - uninstall/delete Bruce Lee and The Sims 3?
    Im not 100% sure but I dont think you can unless you root the phone and I dont think you can root the play yet
  3. #3
    Yes, you need to root to delete it.
    Rooting is possible, it all depends on what type you have. (r800x is Verizon's version, and the dev's have cracked it recently and are working on finding a good way to deploy a SuperOneClick-esqe way to root, r800a and r800i it's also possible (r800i is europe and r800a is canada... i think...) but i haven't been paying attention because i have an r800x :P )
    Update: Rooting means to give yourself administrator privileges for your phone, similar in idea to jailbreaking an iPhone.
    Update: r800x bootloader exploit has been (hopefully temporarily) closed, so in other words, you can't root
  4. #4
    U cant uninstall these fqctory games, all u can do if ddelete the data
  5. #5
    Default
    Factory installed games can be uninstalled. I did that to mine to free up phone memory space.
