Root for the R800x (and possible more!)
Read here: [Only registered and activated users can see links. Click Here To Register...]
Respond in the same thread, i don't check here too often
Guide: With Pictures:
At dropbox.com: [Only registered and activated users can see links. Click Here To Register...]
At Ubuntu one: [Only registered and activated users can see links. Click Here To Register...]
or at Filesonic: [Only registered and activated users can see links. Click Here To Register...]
Re: Root for the R800x (and possible more!)
Thanks to DooMLoRD over in the Xperia X10/Arc/Play side at XDA-Developers.com, he has developed a batch file (windows only) that will run the root for you!
There isn't really any difference between the code he typed out and how you do it here, so head on over, download and root!
fusckin bout time. thanks!!!!!!!!!!!!!!!!!! TOTALLY WORKS ON VERIZON 800X!!!! but gonna worry when ice cream sandwich comes out cause i dont have a clue as to how to update without messing the phone up!!!!!! Spanks for a great tutorial!!!!
Does Rooting our Xperia Play on Verizon, allow us to download any of the apps, that were suppose to come with our phones, but Verizon took away, like the Playstation App, or PS store?
You can do that anyways, if you check the box in application settings that says "allow unknown sources"
Unless you're talking about bravia engine, mega bass, or x-loud, then yes, you need root.
Quote:
Actually, Verizon's Xplay (R800x) is stuck on 2.3.3. PlayStation Store require 2.3.4.
Sent from my R800x using Tapatalk
Touche, good sir. The playstation pocket app, on the other hand, can be run on 2.3.3 (which i have done :P)
Link is not good. got an xperia play that needs a root or a hammer. please repost a good link.
Links are no longer good, sadly. Bummer...
