Results 1 to 3 of 3
    Question how to hard reset this device
    i have tried every possible way to reset it , tried the manu options and does nothing after reseting device and restore from main manu also donet do a thing , and i tried the bootloader way holding down the volume down button and power stimulousley it doesnt work cause thats for (GSM) devices only , please post correct procedure for hard reset from bootloader option , its done with buttons only and i dont know which 1's . anyways if someone has a way to do this procedure please PM me . your help is appreciated and thanks in advance ......
    sincerely : Rymi petro
    Last edited by Paul627g; 03-26-2012 at 11:45 AM. Reason: Removed personal email address for privacy/rules.
  2. #2
    TDMaster's Avatar
    Posts
    ROM
    Xperia Play 4.0.4 Beta
    Default Re: how to hard reset this device
    why do u need do to hard reset?
  3. #3
    stolen fone???, only way is to plug it into computer and downgrade to 2.3.3 or upgrade
