Results 1 to 5 of 5
    kenny38606's Avatar
    Posts
    Global Posts
    7 Global Posts
    Default Need help updating to ICS.
    So, I've installed Sony PC companion and the update starts. It gets to the point where it tells you to unplug the phone, turn it off and wait 5 seconds, plug the cord into the computer and hold down the volume button while plugging the cord into the phone.
    I do this, but the update won't continue. The phone has the charging battery icon on the screen and that's it.
    What am I doing wrong? Please help.
  2. Thread Author  Thread Author    #2
    kenny38606's Avatar
    Posts
    Global Posts
    7 Global Posts
    Default Re: Need help updating to ICS.
    Any help would be appreciated.
  3. #3
    buckwild's Avatar
    Posts
    Global Posts
    314 Global Posts
    Here's how I did it. First plug the usb into your phone then while holding the volume down button on the phone,plug the other end into your pc..hope this helps!
    Sent from my Sony Xperia Ion
    kenny38606's Avatar
    Posts
    Global Posts
    7 Global Posts
    Thanks for responding. Is there a certain length of time I should hold down the volume button? It's still not continuing the update and it's still showing the charging battery icon.
  5. #5
    buckwild's Avatar
    Posts
    Global Posts
    314 Global Posts
    Quote Originally Posted by kenny38606 View Post
    sorry you're having trouble. Have a look at this..
  1. Still cant get manual update to ICS to work, help!
    By 4mooo in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 07-22-2012, 10:57 AM
  2. need help updating to ICS
    By IMS18 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 07-18-2012, 12:07 AM
  3. Help with updating to ICS- CWM prevents it.
    By bangschr in forum Samsung Galaxy S II Skyrocket
    Last Post: 06-22-2012, 10:46 AM
  4. need help updating to 2.2 root from 2.1 root
    By brennan0123 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 10-07-2010, 06:52 AM
  5. Help plezzz need help new to root.
    By knwo in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 02-11-2010, 12:09 PM
