Results 1 to 3 of 3
    tositem's Avatar
    Posts
    Global Posts
    34 Global Posts
    Default Xperia acro S - battery drop 4% per hour, normal?
    Hi everyone,
    Last night i received an update (information is attached), and yes i notice some improvements; like no lags when switching between apps, etc.
    Xperia acro S - battery drop 4% per hour, normal?-uploadfromtaptalk1357720384877.jpg
    But the thing is, when i left my phone for a sleep (for 6 hrs), and i woke up, and i found my phone drains approx. 4% of battery each hour. Is it normal?
    The condition was: it's connected to 3G, auto-sync turned off and nothing running on the back (i task-killed them). Anyone have the same issue?
    Thanks.
    Sent from my LT26w using Android Central Forums
  2. #2
    lynnneil's Avatar
    Posts
    Global Posts
    99 Global Posts
    Default Re: Xperia acro S - battery drop 4% per hour, normal?
    Did you use the mobile data to install the updates?
    tositem's Avatar
    Posts
    Global Posts
    34 Global Posts
    Nope. I was installing it on wifi.
  1. Galaxy S3 Idle Battery Drain of 6% Per Hour Should Be 1% Per Hour
    By Alex Franco in forum Samsung Galaxy S3
    Last Post: 04-05-2013, 09:38 AM
  2. Normal battery drain % per hour: what are you getting?
    By pcguys in forum Samsung Galaxy S3
    Last Post: 02-25-2013, 08:17 AM
  3. Battery drain seems to average around 5% per hour
    By mbranscum in forum AT&T Galaxy S II
    Last Post: 10-31-2011, 10:38 AM
  4. My battery just lasted 3 hours with nothing open.
    By TerryMasters in forum Verizon Droid Incredible
    Last Post: 05-24-2010, 06:44 PM
  5. What happened? Battery died after 3 hours
    By davidlw#ac in forum Motorola Droid
    Last Post: 11-28-2009, 02:47 PM
