1. AlCandroide's Avatar
    Hi, I have a Sony Xperia U running ICS.
    Some time ago, I tried to turn off my WiFi adapter. Surprisingly, i keeps trying it and it gives up after 30 seconds (+/-). This happens every time, now.
    The only way I can turn it off is to reboot my phone.
    It really annoys me because my phone has a horrible battery life.
    I really need help on this one.
    01-20-2013 07:55 AM
  2. Andre Seixas's Avatar
    The same happend to me after installing android 4!
    Everything went well until after a month or so...
    If I repair the phone on Sony Bridge for Mac and re-install android 4, it fixes it but after some weeks the problem resurges...
    I've re-installed android 4 several times but the problem always appears again...
    It's a shame because I liked a lot the phone...
    01-21-2013 07:40 PM
  3. AlCandroide's Avatar
    Can you use a app manager to turn it off?
    Can you suggest me an app manager?
    01-23-2013 03:24 PM
  4. Dmitry Kuish's Avatar
    The same problem with my Xperia U, ICS 4.0.4.(6.1.1.B.1.10) It worked really good after updating, but only for a first month. A week ago wifi in the phone stopped turn off, I re-install android, but it did not solve the issue.
    01-24-2013 04:26 AM
  5. Dmitry Kuish's Avatar
    Get home, connect phone to wifi and reboot xperia U before going outside.
    01-25-2013 12:50 AM
  6. AlCandroide's Avatar
    Nope. It doesn't work either!
    01-25-2013 03:48 PM
  7. Dmitry Kuish's Avatar
    I'm sure that no apps like this "Check out this one https://play.google.com/store/apps/d...etterwifionoff" will work cause problem is inside that version ICS. What I will do I will re install OS without any additional software. I belive that problem came from other software or updates. Wifi in my phone worked perfect for the whole month after updating. I installed something or updeted and then it happend (dont remember which app). If you install one program in 2 days and do no updates you will certainly see which app is guilty in that.
    01-25-2013 05:05 PM
  8. AlCandroide's Avatar
    So you are saying that I have to lose my data?
    01-26-2013 03:28 PM
  9. Dmitry Kuish's Avatar
    what I did, I saved my phone book on the Google. then uninstalled all apps and re install OS, now wifi works just perfect (no additional software). Do you have installed "astro file manager" version ASTRO-4.2.463 ?
    01-26-2013 04:21 PM
  10. AlCandroide's Avatar
    I had it installed before updating my Android from Gingerbread to ICS.
    01-27-2013 09:13 AM
  11. Dmitry Kuish's Avatar
    Yesterday updated all pre installed apps, still works great.
    01-28-2013 11:25 AM
  12. AlCandroide's Avatar
    I tried changing some setting at Better WiFi On/Off and it does great. But if it disabled, the problem stills the same. But thanks for tip. It should work for now
    01-28-2013 01:41 PM
  13. Vindula Ganegoda's Avatar
    wts d app that u use to turn off wifi
    04-12-2013 02:17 AM
  1. Replies: 11
    Last Post: 12-25-2014, 05:58 PM
  2. Screen doesn't turn off when on calls
    By drewsonian in forum Sprint Nexus S 4G
    Last Post: 08-17-2011, 12:40 AM
  3. Screen doesn't turn off while on phone
    By panicprone77 in forum Verizon HTC Thunderbolt
    Last Post: 07-30-2011, 11:11 AM
  4. Phone doesn't turn off?
    By jigz23 in forum Verizon HTC Thunderbolt
    Last Post: 04-10-2011, 02:35 AM
  5. Losing Wifi whenever screen turns off
    By mterui in forum Verizon Droid Incredible
    Last Post: 12-08-2010, 10:34 PM
