Results 1 to 2 of 2
    Default Emergency calls only | No SIM card ~ HELP !!!!!!!!!!!
    There's a SIM card inserted on my ion but on the top right of the screen says " Emergency calls only | No SIM card "... what should I do ? my ion has the latest updates.
    Help please .. thanks
  2. #2
    Default Re: Emergency calls only | No SIM card ~ HELP !!!!!!!!!!!
    You should check your SIM card slot for dirt or dust and check you sim card for dirt too. Try the SIM card on other phone. If this doesn't help than factory reset your phone. If it doesn't work than go to the closest support center.
  1. No Sim Card after flashing Recovery
    By project.in.process in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 09-09-2011, 04:04 PM
  2. No SIM Card after toggling mobile network
    By deesto in forum Verizon HTC Thunderbolt
    Last Post: 08-11-2011, 01:54 PM
  3. SIM card help
    By Stonecold in forum AT&T Samsung Infuse
    Last Post: 06-18-2011, 11:55 AM
  4. Being able to root or use the g1 without a SIM card help?
    By yus4eel in forum Software Development and Hacking
    Last Post: 07-12-2010, 05:02 PM
  5. Emergency Calls Only Message - TMO
    By iamcpap in forum Google / HTC Nexus One
    Last Post: 05-09-2010, 07:54 PM
