1. crazynified's Avatar
    Hi all,
    I need some help with my SD card.
    Recently, I tried to root my Arc but it didn't work, my phone won't start up after the flashing part and I decided to reset my phone to factory settings using Sony Update Service.
    Now the phone's fine and I decided not to root anymore (it upgraded to android 4.0 which is better than my 2.3 before, so I am satisfied with that), but my SD card does not show its contents on my PC when connected by USB. The contents such as music and movie files are still in there when I checked in my phone file viewer, they weren't wiped out, but I can't see these files on my PC at all. The SD card used to have my name as its drive name, but now it only states "SD Card" on my PC. The available empty space is still the same, but it seems my files are hidden or something. Any attempt for me to "import" those files from the SD card to the PC drive seems to result in error.
    Could anyone point out to me what's wrong here? Thanks for any help.
    08-04-2013 11:30 AM
  2. srkmagnus's Avatar
    Hi all,
    First, welcome to the forums! Regarding your problem, you'll need to install the appropriate drivers for your device and computer. Visit Sony's website: Xperia Care Support | Android Smartphones - Sony Smartphones (US), look for your device and install the drivers. There was a change in the way Android allows access to the device from a computer on 4.0+ and often time the device drivers are necessary.
    You can also use a third-party WiFi Transfer App: https://play.google.com/store/apps/d...FiFileExplorer
    There are many others in the Play Store, the above is what I've used in the past and find it easy to use.
    08-04-2013 11:49 AM
  3. crazynified's Avatar
    Thanks for your reply. I tried to install the driver downloaded from sonymobile.com, but it already said that the driver is already up-to-date. I found that some of my files are now visible when I tried to view them on my PC again, I am not sure if the files are slowly coming in or what.
    Appreciate you recommending the WiFi Transfer App, now that shows the entire contents of my SD card. Still, it's not so convenient to download through WiFi all those huge media files that are still hidden on my PC; works for the short-term though.
    08-05-2013 11:24 AM
  1. Phone shuts off when not on charger
    By BGoldsmith in forum HTC EVO Design 4G
    Last Post: 02-20-2014, 02:33 AM
  2. Version of micro SD card
    By Ed27 in forum Samsung Galaxy S4
    Last Post: 08-06-2013, 04:00 AM
  3. how did your web site get on my tab
    By kaschiro in forum Samsung Galaxy Tab 2 10.1
    Last Post: 08-05-2013, 04:15 PM
  4. Screen turns on & disconnects calls
    By w0by in forum HTC One Google Edition
    Last Post: 08-04-2013, 09:01 PM
  5. How can I make emoticons on instagram besides using Emoji app?
    By mrCorduroy in forum Samsung Galaxy Note 2
    Last Post: 08-04-2013, 04:12 AM
