1. clowertown's Avatar
    User of Cyganmod for Android.
    ( I had around 35 % battery , my stupid misstake )
    Friday at work I discovered an new nightly and thought wow.
    Well, I downloaded it using CM Downloader and show a sign “ Go to recovery “
    I hit ok on that and the phone restarted for upgrading and I saw the SONY logo then it got black.
    Thought it was a standard before booting up, later after work I tried to start phone up.
    No respond, just blink 3 times right led light. So I got home and put in charger. But I cant get it up running.
    I believe I got the clockwork installed ClockworkMod Recovery.
    All boot just flashing red light .
    Tips of any kind is more then welcome
    11-16-2013 11:52 AM
  2. UJ95x's Avatar
    Welcome to Android Central
    So you're saying it lost power and turned off while in recovery mode?
    11-16-2013 12:18 PM
  3. clowertown's Avatar
    Thanks UJ95..
    Yes .. got around 30 % power when my phone wanted to restart to complete the upgrade. The Cyganmod called it recovery ..
    11-16-2013 12:46 PM
  4. UJ95x's Avatar
    Thanks UJ95..
    I know but did it die while in recovery or did it ask you to reboot?
    11-16-2013 01:01 PM
  5. clowertown's Avatar
    Yes. Sorry. Correct. Sony logo and then all black.
    11-16-2013 01:14 PM
  6. UJ95x's Avatar
    So it won't turn on now or boot into either recovery or download?
    11-16-2013 01:15 PM
  7. clowertown's Avatar
    No start, just a simple flash on the red light inte the corner
    11-16-2013 01:28 PM
  8. UJ95x's Avatar
    Sounds like it's bricked. Someone else had the same issue last week and I believe he was told the only solution was to find someone who offers JTAG services
    They might be able to recover it. Good luck
    11-16-2013 02:10 PM
  1. Replies: 1
    Last Post: 11-22-2013, 09:29 AM
  2. Replies: 1
    Last Post: 11-22-2013, 09:27 AM
  3. Replies: 6
    Last Post: 11-20-2013, 12:47 PM
  4. SwiftKey keyboard. Quick way to make keys disappear?
    By Misterb in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 11-18-2013, 05:48 PM
  5. Replies: 0
    Last Post: 11-16-2013, 11:42 AM
