Results 1 to 5 of 5
    Hass786's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default experia z and 64bg card issues!
    I was told that in order to use a 64gb memory card with the experia z, I will need to format it. Hoe do I go about it and what do I format it to?
    Mixer_C6 likes this.
  2. #2
    mrsmumbles's Avatar
    Posts
    Global Posts
    4,272 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: experia z and 64bg card issues!
    If you put the card in the phone and find the option to format it, what does it say?
    Sent from my LG870 via Tapatalk 2
    Hass786's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There isnt a option to format at all ...
  4. #4
    mrsmumbles's Avatar
    Posts
    Global Posts
    4,272 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by TheSultan View Post
    1. The message "being delivered" is not a blackberry thing, it's a Verizon thing. Any verizon phone should be able to do that. With that being said, I haven't seen it done on the Eris in either Messages or the HandcentSMS app. Interesting...
    2. Locale Notification Plug-in v2.6 Application for Android | Productivity
    Never used that, I never used anything like BerryBuzz when I was on the BB platform, but, is that what you're meaning?
    In settings, under storage, external sd card, is there an option to format after you put the card in? Is your phone seeing the card?
    If not, I'm stumped other than to do what I did and buy a 32 gig sdhc card unless you have use of a computer that can reformat the 64 gig card.
    Sent from my Nexus 5 using Tapatalk 2
  5. #5
    mrsmumbles's Avatar
    Posts
    Global Posts
    4,272 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mrsmumbles View Post
    You need it formatted in FAT32 file system, probably.
  1. HTC One Dual Sim SD Card Problem
    By XtremeAladdin in forum HTC One M7
    Last Post: 11-14-2014, 04:23 AM
  2. Ring and vibrate??
    By Ni Hammad in forum Samsung Galaxy Gear
    Last Post: 01-28-2014, 11:17 AM
  3. Whatsapp and Nexus 5
    By AndroidDario in forum Google Nexus 5
    Last Post: 12-27-2013, 04:18 AM
  4. Bluetooth issue
    By Sodathief in forum Samsung Galaxy Note 3
    Last Post: 12-25-2013, 11:38 AM
