Results 1 to 4 of 4
    Default Authentication Problem Solved
    I know a lot of you guys, android users faced this problem, I've red a lot of threads about it. Some of user say that you have to buy new router. But that is not truth. Easiest way to solve this problem is to go to:
    Control Panel/Network/Network Infrastructure and press the second mouse button on your routers icon/Then press View device webpage/When you are in the webpage you'll need login and password which is usually admin, admin. Press ok and continue/Go to Network Connections/LAN Wireless 802.11g Access Point (it's called that in my computer)/Wireless/Then search for name "security" after that you just choose security type near that name and just select "None"/Confirm your change in the bottom of the page and you should probably have no authentication problems from now on. (Marking security as "None" makes your connection password disappear. But I believe if you put your security back on you'll have the same error back again.
    Even if you won't have the security, you will still save up some money instead of buying new router.
    Also I didn't checked all of the security possibilities. Some of them might also work.
  2. #2
    Default Re: Authentication Problem Sloved
    Welcome to Android Central, and thanks for that input. I would caution people against completely removing router security, though, unless they have no nearby neighbors who could potentially piggyback off their internet or worse yet, snoop or hack into their network.
  3. #3
    Why there's no Network Infrastructure here to click? Please Help me
    Quote Originally Posted by RoselleQte View Post
    It's like a category, not a folder. Just right click on your modems icon and that's it.
  1. HTC One Battery Problem
    By connorp12 in forum HTC One M8
    Last Post: 05-16-2015, 06:38 AM
  2. Galaxy S4 Bluetooth microphone problem.
    By Xuaran in forum Samsung Galaxy S4
    Last Post: 06-05-2014, 12:38 PM
  3. connection problem on mobile data
    By Yhuan Theodore Capia in forum General Help and How To
    Last Post: 04-11-2014, 02:28 AM
  4. Youtube video problem [HELP]
    By zenos71 in forum Samsung Galaxy S4
    Last Post: 04-09-2014, 12:39 PM
  5. HDMI problems
    By Pat Kerby in forum HTC One M7
    Last Post: 04-09-2014, 07:56 AM
