Results 1 to 5 of 5
    rearview's Avatar
    Posts
    Global Posts
    135 Global Posts
    Question upgrade to 2.1 problem
    I just acquired an X10 and I'm trying to put SonyEricsson's 2.1 on it. I downloaded the PC Companion and the Update Service from their website. PC Companion tells me "your phone is up to date." I've done a "repair" (only option available to me since "my phone is up to date") through both the Companion and the updater. I'm still running 1.6.
    Is there a way to make this work?
  2. #2
    Default
    If its an AT&T phone you need to debrand first. I used the divinci team to do this. Then use Sonys update program and it will let you update to 2.1
  3. #3
    Diesel984's Avatar
    Posts
    Global Posts
    805 Global Posts
    Default
    You can check the Forums over @ XDA too...There's a HUGE tutorial on how to flash it to 2.1 there...
  4. #4
    Default
    where can i get Divinci team to unlock my xperia x10a??
  5. #5
    ddymond's Avatar
    Posts
    Global Posts
    33 Global Posts
    Default
    they have a website, but you have to pay
    Upgrade Xperia X10 to Android 2.1 — DavinciTeam Blog | creative mobile applications
    let me know how it goes if you do it. I have been on the aprehensive side about doing it, but AT&T is dragging their feet to much for me.
