1. enthused91's Avatar
    I'd like to get some input on my sero's battery, as it seems like it almost completely drains after just sitting, not being used for 8 hours and I'm wondering if I have a defective battery -- I also only have 4 more days to decide whether I want to return it.
    I also had it plugged in overnight once and in the morning found it to be EXTREMELY hot and unwilling to turn on at all -- then I left for work and 8 hours late, when I plugged it back in I was able to turn it on but the batter was completely drained. Don't know what this means, and it hasn't happened again, but it makes me worry that my tablet might have a defect.
    So I downloaded 'Battery Monitor' widget, which has in depth graphs to diagnose battery issues, however my problem is, I don't know what is normal and for the most part what anything means -- but I thought I'd attach screen captures of the graphs and was hoping maybe someone could tell me if they indicate I have a crappy batter or if this is normal for the Sero 7 Pro.
    Any help or insight would be GREATLY APPRECIATED!!!
    Hisense Sero 7 Pro -- Battery-screenshot_2013-09-26-19-23-38.pngHisense Sero 7 Pro -- Battery-screenshot_2013-09-26-19-23-42.pngHisense Sero 7 Pro -- Battery-screenshot_2013-09-26-19-23-45.pngHisense Sero 7 Pro -- Battery-screenshot_2013-09-26-19-23-53.pngHisense Sero 7 Pro -- Battery-screenshot_2013-09-26-19-24-04.png
    09-27-2013 01:46 PM
  2. HULKchampion's Avatar
    Return it and get another Sero Pro 7. You might have a defective battery. My Sero gets about 4-5 hours of usage after unplugging 100%. That's playing games, streaming movies, playing music and stuff.
    09-27-2013 05:09 PM
  3. enthused91's Avatar
    Well what is weird is that mine gets that many hours of usage when I am using it too -- but it seems to really drain when it is NOT being used, at least more than I would expect. But when I am using it, it drains at a normal rate that I would expect... which makes no sense to me.
    09-27-2013 07:35 PM
  1. Battery Cover?
    By BrakeTurnAccelerate in forum Samsung Galaxy S4 Active
    Last Post: 02-01-2015, 11:56 PM
  2. Please Help!!! Bad battery life!
    By JaiHook in forum Verizon Galaxy Note 2
    Last Post: 09-30-2013, 06:30 PM
  3. Please Help!!! Bad battery life!
    By JaiHook in forum Samsung Galaxy Note 2
    Last Post: 09-30-2013, 04:24 PM
  4. Replies: 2
    Last Post: 09-27-2013, 11:53 PM
  5. Battery drain
    By Cavidos in forum Samsung Galaxy S II
    Last Post: 09-27-2013, 12:24 PM
