1. JT Peters's Avatar
    I have a Nextbook 8 (4.1.1) and a Galaxy S4 (4.4.2) Both have 8 GB internal memory and a 32 GB SD card. On the Nextbook I keep having to clear the cache and when updating Apps I have to uninstall a few so I have enough memory to work with. I've moved all the apps I can to the internal SD card (I understand that is about 7GB of the 8 GB and the other GB is for the system.) Looking at the system I see the 1GB is nearly full but don't see how to see what is on it that I might be able to remove. I don't have any problem with the S4. Any suggestions?
    07-29-2014 11:41 AM
  2. B. Diddy's Avatar
    Let's make sure we're on the same page. The regular S4 (not the Mini) should have 16 GB of internal storage, of which around 7 GB are taken up by the OS, TouchWiz, and other bloatware, leaving a little over 8 GB available to the user. As far as I know, the regular S4 doesn't come in an 8 GB version.
    The Nextbook 8 has 8 GB of internal storage, of which probably around 3-4 GB are taken up by the OS and bloatware. So the available internal storage to the user is probably around 4 GB. So it shouldn't be too surprising that the Nextbook runs out of storage sooner than the S4. Let me know if I'm getting this wrong.
    07-29-2014 12:25 PM
  3. JT Peters's Avatar
    You are mostly correct - I erred with the S4 memory. The Nextbook divides the 8GB into 1 and 7 GB partitions. I believe the 7GB is what is used when I move an app to the SD card. I have plenty of room on the 7 GB part. Just can't seem to empty anything else out of the 1 GB partition.
    07-29-2014 01:29 PM
  4. B. Diddy's Avatar
    The Nextbook's storage partitioning is what's getting you. The 1 GB partition is likely the app storage, while the 7 GB partition acts as an "Internal SD." App installation is primarily to the 1 GB partition, although portions of the app can be moved to the Internal SD. The problem is that the app has to be able to install first to the 1 GB partition, and if there isn't enough room for that initial install, you'll get a low memory warning.
    See this guide for more info: http://forums.androidcentral.com/amb...-warnings.html
    07-29-2014 01:44 PM
  5. Faith Beck's Avatar
    I just bought this next book 8 and I have a memory card in it I have only downloaded two games and I have moved everything I can to the SD card but I'm still out of space. It came with certain apps that I can not delete or it says that it won't run right. Is there anyone that can help me please?. And Thank You I would really appreciate it.
    03-06-2015 01:43 AM
  6. davndian's Avatar
    i am having similar problems, i just got this tablet a few days ago and only downloaded severl apps and i am already getting that box that i have low memory and to delete some apps. this is crazy and another thing i put a 16 gb sd card in and i have gone all thru my settings and apps and i cannot find the way to move my apps from device to sd card so please tell me how you did that. your problem and mine also i think is that they the co. just puts too much extra junk on internal mem that is not sufficient enough for the tablet. i am thinking of taking mine back, i only got it for the quad core processor. get back too me. thanks david
    02-06-2016 02:21 PM
  7. davndian's Avatar
    i don't know if i can help you or not, i am having the same problems, but i can't find the way to move apps from the device to the sd card, its not like my samsung tablet where i just clic on the app out of settings and then app manager. i had the option of moving the app to sd or to the device and i can't do that with this tablet. whats the way. thanks for any help you can give me or may just take the thing back.
    02-06-2016 02:30 PM
  1. admob virus on galaxy s5
    Last Post: 08-08-2014, 07:23 AM
  2. my phone made a loud shrieking noise and went black
    By dovakar in forum Google Nexus 4
    Last Post: 07-29-2014, 03:50 PM
  3. Does it make sense cost wise to fix my S4?
    By delta7 in forum Sprint Samsung Galaxy S4
    Last Post: 07-29-2014, 03:41 PM
  4. Replies: 1
    Last Post: 07-29-2014, 11:46 AM
  5. change amdroid id on cloned cm7 micro sd card
    Last Post: 07-29-2014, 11:14 AM
