Results 1 to 2 of 2
- 01-29-2011, 11:17 PM
Thread Author #1
- 02-09-2011, 08:48 AM #2
Make sure there's NOTHING else on your SD card first. Then. I'd recommend finding Cyanogenmod 6.x. It's what I'm currently running on mine, and it works like a champ. Throw that on your SD card, hold down the Volume + button and hold the powerswitch on...and voila. Although....the white PDN or black PDN? Which are you using...?
Reply
