1. rkhanso's Avatar
    Yes, I searched this forum for 'wifi hotspot' and did not get any hits.
    My old VM Optimus V was rooted and had Harmonia ROM on it. Harmonia came with WiFi hotspot capability.
    I got a new VM Supreme phone and it doesn't appear to be able to do WiFi Hotspot. I even rooted the phone, but there are no ROMs that I can find for it.
    Is it possible to get WiFi Hotspot to work on this phone?
    Thanks.
    01-16-2014 12:54 PM
  2. TheNarrator's Avatar
    Have you tried an app like Barnacle? One of the ROM's I used (Quattrimus maybe?) didn't have working hotspot, so I used the app and it worked nicely.
    01-16-2014 01:28 PM
  3. rkhanso's Avatar
    I have tried about 5 -6 different apps on the play store. None of them worked for me. Some of them were just widgets to turn on the 'built-in' wifi hotspot (which there is none).
    I haven't found one that works yet on the VM Supreme, or at least I haven't been able to get one to work.
    I did try Barnacle. It doesn't appear to use the WiFi. I never see an SSID when trying to connect to it. I never see the WiFi icon in the notification bar. I do have WiFi enabled in Android settings on the ZTE phone.
    01-16-2014 01:42 PM
  1. 4.3 downgrade to 4.1.2 possible?
    By shrubr in forum AT&T Galaxy Note 2
    Last Post: 07-03-2014, 08:55 AM
  2. Samsung Galaxy S3: Verizon free wifi won't work after today's update
    By DavidKoss1 in forum Verizon Galaxy S III
    Last Post: 01-29-2014, 10:43 AM
  3. Replies: 5
    Last Post: 01-21-2014, 06:22 PM
  4. How do I try out T-Mobile's network?
    By jerrykur in forum T-Mobile
    Last Post: 01-17-2014, 07:15 AM
  5. Wifi connected but internet not working
    By Chruptak in forum HTC One M7
    Last Post: 01-16-2014, 11:29 AM
