1. chuber000's Avatar
    My rooted zte warp sequent is stuck in a bootloop. Ive tried flashing different ROMS and none of them install correctly or boot up. I have wiped data/cache and did a delvik cache wipe many times. I can not turn on usb debugging and as such it will not show up in adb:devices. I've tried flashing the stock JB kernel and a stock ROM but no luck. Any advice on how to fix my phone would be really helpful.
    02-14-2014 05:20 PM
  2. Melvin Stevenson's Avatar
    try using fastboot. up+power for 10 seconds. you will see an andy the android. next go to zte website and download their update and follow all instructions. it will install 4.0.4 ics. hope that helps
    05-04-2014 08:51 PM
  3. mo duncan's Avatar
    I Have a issue with my hardware after using TWRP to flash a custom Rom on My ZTE boost Max N9520 stormer rooted with Kingoroot PC program. Did backup my data but erased SD card once I wiped partitions and dalvic. Now its only a red light and blank screen. I can't boot into recovery system neither only FTM Mode. When my phone does boot it only stays on for about ten seconds and reboot back to DFU Mode red light black screen. Using ZTE handset tool for PC does work but only reset phone. Help me out in 2016 soft bricked for sure.
    01-23-2016 07:08 PM
  1. Burn in on IPS display?
    By brandonx1000 in forum Verizon LG G2
    Last Post: 02-16-2014, 08:06 PM
  2. Question about AnTuTu in Asus Fonepad 7
    By Hossein Dibapour in forum General Help and How To
    Last Post: 02-14-2014, 01:38 PM
  3. Tune in Pro Vs. Bluetooth
    By David Maniowicz in forum Motorola RAZRi
    Last Post: 02-14-2014, 10:04 AM
  4. APN doesn't save in Tablet AOC Breeze
    By Galled in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-14-2014, 08:28 AM
