1. Chrazy's Avatar
    Not sure how to fix My Wi-Fi because it doesn't want to connect..
    03-28-2014 07:58 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It'd help if you told us more info, like the model of your phone, the version of Android, in what circumstances the error message occurs, what you've tried to solve it, etc.
    In the meantime, review this guide: http://forums.androidcentral.com/amb...-problems.html
    03-28-2014 08:51 PM
  3. pixelpadre's Avatar
    I am having the same problem with my new ATT Radiant. z740, Android 4.1.2.
    It did work out of the box but has since stopped connecting. Today, while on the road it did connect to Dairy Queen wifi.
    My router is DIR 601 Dlink. Wireless N150 router.
    I suppose I could do a factory reset, but if I have to do that each time I lose wifi connectivity , that just won't work.
    06-07-2014 03:54 PM
  4. tommybot's Avatar
    to both users. my short term fix is turning your wifi off on your phone(wait 30 seconds) and then turn it back on. if the wifi does not turn off on your phone. or that fails to fix the problem. put your phone in airplane mode. wait 30 seconds. turn airplane mode off then turn your wifi back on.
    you shouldnt need to do anything to your router.
    at my house everyone connects fine. my wifes phone just wont connect to wifi. so that is what i do to get it to connect. im trying to find a more permant solution.
    12-28-2014 03:22 PM
  1. Google Play Store Not Installed
    By subyroo in forum Google Play Store
    Last Post: 03-30-2014, 08:13 AM
  2. Galaxy S3 not being allowed to update past 4.1.2
    By lovenokia in forum Samsung Galaxy S3
    Last Post: 03-29-2014, 01:05 AM
