1. AC Question's Avatar
    I currently own a Samsung S6 Edge, and I was looking into purchasing a Note 4. I want to purchase the Note 4 because of the removable battery, expandable storage, bigger display, the S Pen, and its ability to upgrade to 6.0 Marshmallow. I wanted to get the Note 5, but its missing a lot of what makes the Note 4 great, plus the increased price. Is it reasonable to downgrade from an S6 Edge to the Note 4? Thank You!
    07-19-2016 12:57 PM
  2. belodion's Avatar
    I'm not a Samsung user and Samsung users will probably have definite ideas about this. I'd say that it's reasonable to do it if you prefer the Note 4 to the S6e.
    Now, I'll just find some Samsung users who will tell me I'm wrong. It wont take long.
    mehigh101 and SmashBruh like this.
    07-19-2016 02:31 PM
  3. mehigh101's Avatar
    Actually,you are right,belodion!
    As for the question,if you already bought the s6 there's no reason to buy the note 4 as well,and i think the s6 edge is way better. Just an opinion.
    Sent from Samsung Galaxy S7 Edge SM-G935F
    belodion and SmashBruh like this.
    07-19-2016 02:35 PM
  4. Aquila's Avatar
    The phones were released almost exactly 6 months apart and so there's not a lot of "tech" difference between them that's going to be noticeable over a long period. If you like the s-pen, larger display, etc. there's not a lot to lose by "downgrading", especially with how terrible the S6 battery life is compared to the Note 4, Note 5 and S7 devices. The other most obvious answer is to get the Note 7, which should be announced in two weeks and is for obvious reasons better than all the other devices on this post.
    07-19-2016 02:40 PM
  5. LeoRex's Avatar
    yeah, I'm with my boy Aquila here.... the S6 and S6 Edge had a massive fatal flaw: the battery was brutally undersized. If someone handed me both phones and asked me to keep one, I would go with the Note 4 every time.
    belodion, SmashBruh and huntnyc like this.
    07-19-2016 02:46 PM
  6. SmashBruh's Avatar
    I know this is an anon question, but it was actually me who wrote it because i did not sign in. Thank you all for answering, this helped me a lot!!
    07-19-2016 09:53 PM
  7. Aquila's Avatar
    Welcome to the forums. You decide which you'll do?
    07-20-2016 06:42 AM
  8. SmashBruh's Avatar
    I've decided to wait for the Note 7 announcement that's around the corner just to see what it has to offer. At this point I'm leaning towards getting the Note 4, but who knows the Note 7 can really surprise me !
    Aquila likes this.
    07-20-2016 10:46 AM
  9. Morty2264's Avatar
    I am not a Samsung owner, but I do prefer the S6 Edge... But it sounds as if you have done your research/know what you are looking for in a phone; and that you are leaning towards the Note 4. If you want it, you should go for it!
    07-21-2016 09:18 PM
  1. How do I clear my calendar on my Galaxy S7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 02-19-2017, 01:03 AM
  2. Rumor: Samsung could still unveil a flat Note 7 after all
    By nonie in forum Samsung Galaxy Note 7
    Last Post: 07-24-2016, 11:18 AM
  3. Replies: 2
    Last Post: 07-22-2016, 09:34 AM
  4. Set a repetitive reminder on my Note 5?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 07-19-2016, 01:11 PM
  5. How do I clear my calendar on my Galaxy S7 Edge?
    Last Post: 07-19-2016, 12:10 PM
